cant spin
Old Apr 17, 2006 | 10:59 PM
04blackvho's Avatar
Unhappy cant spin
i tryed power braking it wont it will just rev i trow it in 1st gear at 25mph still not even a shrip cant even spin off the line whats the deal
Old Apr 17, 2006 | 11:03 PM
TouchOfEvil04's Avatar
Its heavy,your tires are doin what they are intended for, you have tourque managment holdin you back and what wheels do you have stock size?....
Old Apr 18, 2006 | 12:29 AM
04blackvho's Avatar
stock 17's 245/70/17 there the 5 star looking ones
Old Apr 18, 2006 | 12:48 AM
You could try backing off the brake pedal a little.Unless your torque managment is holdin you back that much i don't see why you can't spin em.Do you ahve traction control on your truck?If you do then thats just another thing that makes it pull timing and so fourth so you can't spin em.
Last edited by TouchOfEvil04; Apr 18, 2006 at 12:49 AM. Reason: Hit the button before i finished typin....
Old Apr 18, 2006 | 12:49 AM
When mine was stock i could power brake it punch it off the line whatever and it would spin.Stock it woudnt spin alot off the line but it would spin some....
Old Apr 18, 2006 | 01:27 AM
01fastz28's Avatar
Banned
I guess that gives you a reason to get a Radix!!!
Old Apr 18, 2006 | 01:30 AM
04blackvho's Avatar
no i dont have trancion controll i had a 6.0 with 345 hp stock in a 04 truck could spin till 35mph if i wanted to this 06 truck has the 5.3 295 hp stock
Old Apr 18, 2006 | 01:31 AM
I didn't think to ask before but does your truck have the G-80 in it?If so that could very well be the reason it won't spin off the line are anything like that.If your not sure look in the glovebox and look for the code that says G-80 on it.If you see it then you got the stock crapper....i mean yeah.Its a pile of a unit but it will lock up and make it so your tryin to turn both wheels resulting in a spin less stock 5.3L
Old Apr 18, 2006 | 01:34 AM
Well spinning can be fun but when i ahd my e-fans,cai,exhaust and headers put on with the peg leg lol....I could punch it off the line an hold it spinning at 80mph until i let off.It really woudn't hook up unless i gave it less gas.Which also ment if i did a punch anywhere in first gear it was useless because it would just spin.I found that the only way i could do punches was at 41mph my lowest point in second gear up to about 49 then from 49-55 i had enough power to make it spin so no punches in that area...sOOn i only could race and ahve a chance at a 60mph roll.It kinda sucked honestly.
Old Apr 18, 2006 | 06:37 AM
5.3AlmnBlk's Avatar
I have a 5.3 ECSB 4x4 and i can spin them easely the way i do it is power brake it untill the point the truck doesnt go foward anymore than slowly press the gas and around 2500rpm it will start to spin and i just puch it slowly i never tryed on the brakes and then just punch it, and i got a g80 and 265/70/17 tires.
