anyone interested in helping out a fellow pt.net member?
Old Oct 8, 2013 | 04:35 PM
abey15's Avatar
Default anyone interested in helping out a fellow pt.net member?
guys i have a boost and afr gauge that i need installed and i hear this sucks to do.... any of yall do this or know somebody that will without me having to drop half a dang paycheck on it?
Thanks ahead of time!!
Old Oct 8, 2013 | 04:39 PM
Mangled03gmc's Avatar
Baltimore Whore
It is not hard to do at all man. The boost gauge is simple. The AFR is the only thing that my be a little tricky, cuz you have to weld the bung into the pipe. Other then that fairly simple. If I were closer i would help
Old Oct 8, 2013 | 04:43 PM
walledition's Avatar
i had fun installing my afr gauge
Old Oct 8, 2013 | 04:59 PM
abey15's Avatar
crap i guess ill have to attempt this myself...
anybody have some handy info that i might need to know?
where yall wire into?? etc?
Old Oct 8, 2013 | 06:26 PM
TIM Z's Avatar
11 sec. Truck Mod
Cool I'm glad you have these gauges you'll need them .
If your rear O2 sensors are turned off in the tune you can unscrew one and screw in your wideband sensor .
Boost gauge is super simple , just find a vacuum port / hose that runs from the back of the blower , cut into it and install a " tee" fitting , then connect your tubing /hose from the tee to your boost gauge .
The power and ground connection can be made in the fuse box, it's just for a light in the gauge and you'll have to tap into the vehicle lights dimmer switch also .
Old Oct 8, 2013 | 08:59 PM
abey15's Avatar
A t? It's got a 1/4 inch nipple wouldn't that work
Old Oct 8, 2013 | 09:35 PM
Chevy_King1500's Avatar
hardest part is tucking all the wires and making it look good
Old Oct 8, 2013 | 10:53 PM
abey15's Avatar
Ok? Any pointers to make it easier or cleaner? Clips I should b extra careful with?
Old Oct 8, 2013 | 11:02 PM
What kind of gauge pod do you have? I ran my wire down the a pillar thru the fuse compartment thing down the kick panel and then drilled a 1/2" hole in the firewall/floorboard put everything in a wire loom from the part underneath the carpet to where they end on the engine/exhaust
Old Oct 8, 2013 | 11:08 PM
Three6GMC's Avatar
if you were located near Corpus i could help you out...
