Any roofers/anyone with roofing knowledge here?!?!
Old Sep 15, 2010 | 09:29 PM
charcoal03silvy's Avatar
Default Any roofers/anyone with roofing knowledge here?!?!
As some of you have seen in one of my signature pictures, I am indeed a Scout. I am working on getting Eagle and have everything done but my project. It has to be for the benefit of a non-profit organization yada yada yada.
Long story short, I turn 18 in February, and have to have this done by then. I need to go before the board with project plans in 4 weeks. Basically, the project I have found and come up with is redoing a roof on a pavilion at a CampFire USA camp. By redoing the roof I mean completely tearing down the pavilion except for the vertical support beams.
Dimensions are roughly 16' by 16'. Roof will not have a crest, one side is higher than the other.
If there are any roofers here, or anyone with roofing experience/knowledge, I would really appreciate input on materials and plans!!
PM me or post here if you have any questions.
Picture:
Old Sep 16, 2010 | 12:08 PM
RibeiroBJJ's Avatar
Praise The Lowered
I can help you..I am pretty good in all trades, and am a Union sheet metal worker of 14 years..We do alot of copper/metal roofs and waterproofing is a large part of my job..
-A few questions..
-Are you replacing all wood other than 4x4 posts?(2x6 rafters/plywood sheathing)
-Do you have any tools for this project ?(determines which way you will do it)
-Do you want to do a bullet proof/badass job? or just replace whats there?
I will help you get it done after yoyu let me know a little more,...send me a pm if you like...
Old Sep 16, 2010 | 03:47 PM
i'll shoot you a pm when i get home from work with some more details.
I do have tools, the plan is to replace EVERYTHING besides the 4 by 4 uprights.
Old Sep 16, 2010 | 09:21 PM
jonathan734's Avatar
I am a roofing contractor. That should be cake, a great "first" roof for you to do. What type of roof are you looking at? Shingle, Metal, Rubber? If you are on a tight budget you could ask some local farmers if they have any old metal roofing materials. Around here everybody with a barn has a couple panels, I would donate mine to the scouts if asked. Are you just wanting to rebuild it the same? Good luck, fill in some details and we will try to point you in the right direction.
Old Sep 16, 2010 | 09:29 PM
Planning to replace all wood except for the 4x4 posts. Undecided on whether to do a corrugated metal roof, or a shingle roof still. I know a metal roof will probably me more expensive, put will last longer, look better if done properly, and is lighter weight.
Thinking about doing the frame from 2x6s with joists every 18 inches.
Old Sep 16, 2010 | 09:36 PM
lady3bglover's Avatar
Good luck on your roof build. Once you get your plans in order, I suggest you go to a local sheet metal guy and ask for a donation. Put his name on a plaque or something....just a thought.
Old Sep 16, 2010 | 10:19 PM
I have decided to go with corrugated metal roofing panels.
Old Sep 16, 2010 | 10:35 PM
Good choice on using metal. If your columns are in good shape, I'd keep them and redo everything else. Redo all the 2x6 rafters and do a better job with spacing. Odd spacing like what is there looks like crap. 24" o.c. is what you need to shoot for. If you're using PT wood, be sure to use galvanized or stainless hardware. I've pulled 16d common nails out of PT wood that was only a year old and they were falling apart already.
Old Sep 16, 2010 | 11:20 PM
It currently is 24" on center for the most part anyway. i'm leaning towards 18"
Old Sep 16, 2010 | 11:38 PM
18" is an odd spacing to work with. I'd stay with 16"oc or 24"oc.
SloSVO
Nov 22, 2020 07:34 PM
Porscharu914
14
Jan 20, 2016 10:45 AM
drummer0415
11
Oct 24, 2015 08:16 PM
slowec
Sep 25, 2015 11:20 AM
Big_pimie
Sep 22, 2015 09:07 PM
