2004 5.3 turbo build
Old Jan 3, 2018 | 12:10 PM
Bmauch's Avatar
Registered User
Default 2004 5.3 turbo build
I am going to be installing a racemmi twin turbo kit on to a 2004 chev 1500 . Dose anyone have any experience with the race mmi turbo kit , other parts needed for the build ? I did order 850 cc injectors boost controller and gauge .
Old Jan 3, 2018 | 04:43 PM
FFDP's Avatar
I had to google that one, never heard of that kit before.
You'll still need a few things though. Larger fuel pump, 2 or 3 BAR MAP sensor, different spark plugs.
Depending on the tuning route you go, ideally going to a speed density operating system with something like HP Tuners would be a good idea. Delete the MAF sensor and wire in a separate IAT sensor into the intake pipe or manifold. Then get it all tuned for the changes.
Old Jan 3, 2018 | 05:02 PM
Bmauch's Avatar
Registered User
What hp tuner do you recommend ?
Old Jan 3, 2018 | 05:08 PM
Bmauch's Avatar
Registered User
I was going to eventually go to a Holley dominator fuel pump and 5/8 fuel line
Old Jan 3, 2018 | 05:20 PM
FFDP's Avatar
Stock fuel lines will support plenty of power, unless you really plan to tax those turbo's.
If you plan to do the tuning yourself and learn yourself, the pro version of HP Tuners is a good idea. It's going to be a long learning process if you've never used it before.
Old Jan 4, 2018 | 06:21 AM
Bmauch's Avatar
Registered User
I ordered the hp pro tuner last night , Bryan Tolley stage 2 boost cam kit , upgraded fuel pump , 2 bar and 2 bar map sensors , 1.7 roller rocker kit , iat sensor .
Vortec350ss
Jun 26, 2023 11:17 AM
Fullpower
Dec 16, 2016 08:22 AM
seadog
Nov 15, 2016 01:09 PM
03chevytruck
Nov 7, 2016 04:43 PM
justuc
Nov 2, 2016 11:45 AM
