07 trailblazer new window regulater now controls are backwards?
Hello I swapped in the new cable style 07 trailblazer new window regulater now controls are backwards? I actualey have Saab 97x same as trailblazer.
I removed and replaced the complete assembly exactly (window at same height) as it came apart however when I press down window wants to go up and vice versa.
The electrical connections are all keyed so that eliminates the possibility of wire reversal.
Here’s the part I have for the front driver side door first one on this link https://www.partsgeek.com/catalog/20...lator_assembly
When the window failed I was out of town in Florida w/ 100%rain luckily we had a traupe to cover window stuck half down.
Before part arrived I was cruising around w/ the window duck taped to door now there’s extra stickie 3m duck tape glue inside some of the window seal making it difficult for window to slide, will clean w/ goof off.
I post image of what I’ve done. Thanks for advice.
I've never tryed auto up I don't think it doe's though. where should I switch the wires?
I thought the geek sent me the left side like dosn't the right side work the opposite of the driver?
first off I will clean all the 3m duck tape residue that was a mistake however it was 100%
rain and I didn't want to ruin the inertia.
could the the stickie window is effecting the controls porlarity? not the polarity because it's hardwired to the electric engine thought maybe the cars computer now controls windows.
sure hope the rear windows motor doesn't break because they are extremely expensive to replace? why so pricie on the rear regulater?
edit: I was am still am happy that the window is in the up position even though I'm not rolling it down. this is the rainy time of year.
I haven't pressed the window down and let it run though a complete cycle of either up or down because w/ the window not securely attached to regulater window isn't completely on track.
c5turbo
05-14-2010 04:40 AM
RickLowpez
06-25-2009 08:16 PM
foxracingfreak
08-24-2006 10:08 PM
parish8
04-18-2003 08:07 AM
