TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Will this tire fit?
Old Mar 9, 2008 | 05:28 PM
99-LS1-SS's Avatar
STF Veteran
Default Will this tire fit?
I have a 2005 Tahoe Z-71 and I'm getting ready to replace the stock Goodyears. Currently I have 265/70-17 and I want a bigger tire. I was wondering if the BFG All-Terrain TA 285/70-17 will fit on my stock rims? The guy at Discount tire told me that he couldn't put them on because I have 17" x 7" rims and they wouldn't fit. I called the dealership and they said the rims were 17" x 7.5" rims plus it's stamped on the back of the rim. From what I've read the 285's will go on the 7.5 rims. Does anyone have any input on my issue? Thanks.
Old Mar 9, 2008 | 07:17 PM
venomhp's Avatar
your tire will mount up with no problems, its just a little tougher to mount, the only fitment problems you might have is rubbing up front unless its lifted, otherwise if its stock those wont fit without cranking the torsion bars which I wouldnt advise it
Old Mar 9, 2008 | 07:32 PM
99-LS1-SS's Avatar
STF Veteran
Why would you advise against raising the torsion bars? Sorry for being a 4x4 noob.
Old Mar 9, 2008 | 07:41 PM
RandomHero's Avatar
Not really sure why he would. As long as you don't go too crazy with it(2" or less) you'll be fine. There have been tons of people who crank with no problems.
I wouldn't recommend it if you're running some serious horsepower(500+)
Old Mar 9, 2008 | 07:42 PM
99-LS1-SS's Avatar
STF Veteran
With the stock 5.3 I'd be suprised if I was pushing 190 horsepower. lol Thanks for the post.
Old Mar 9, 2008 | 08:16 PM
svensk's Avatar
Yes, they will fit just tire people trying to cover their asses. You will have rubbing issues with that wide a tire. Just keep an eye out for cupping and maybe get an alignment done after.
Old Mar 9, 2008 | 08:33 PM
99-LS1-SS's Avatar
STF Veteran
My plan is to raise the front up and get it aligned when the tires get put on. Will the rubbing be bad or only a little?
Old Mar 9, 2008 | 08:40 PM
StrokerAce03's Avatar
Rubbing would be minimal if at all at stock height. You should be good to go.
GXPJAY
Feb 13, 2022 08:15 AM
Zizzle
Oct 19, 2017 08:44 PM
Corvette454l88
Sep 1, 2016 01:24 AM
Ammadien
Jul 22, 2015 08:50 PM
