TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
WHat do you guys think?
Old Aug 18, 2006 | 05:47 PM
gao8302's Avatar
Default WHat do you guys think?
Do you think that a 6" lift will look stupid with a set of 33x12.50x16 mickey thompson baja claws. Tell me what everyone thinks please. I have 36" tires now but i want to down size the lift and tires because i want more HP and the tires are holding me back. If anyone has any pics of what this looks like that would be great.
Old Aug 18, 2006 | 08:49 PM
beastmode's Avatar
Import Moderator
i think you would be very disappointed at how small your truck would look with 33s, even 6" is alot of lift, i have 4" and i know for a FACT i can fit bigger tires, my wheel gap looks really stupid with just 33s but i dont wanna run anything bigger than that, what do you have a 3" body and 6" suspension?
Old Aug 19, 2006 | 10:38 AM
gao8302's Avatar
Yes i have a 6" suspension and a 3" body lift. I want to take the body lift off. What do you think is the smallest tire i should run with just the 6" lift. I had 315/75/r16 on there before and now i have 36" tires.
Old Aug 19, 2006 | 04:30 PM
gao8302's Avatar
Anyone have any ideas on this?or suggestions.
Old Aug 20, 2006 | 10:38 AM
04BlackGmc's Avatar
10 Second Club
i think you would be towering over them which looks stupid.
Old Aug 20, 2006 | 01:49 PM
samdogmx's Avatar
8 Second Club
leave the body lift & take the suspension lift off.
Im running 305/70/16 with a 2" body lift & ford keys up front
Old Aug 20, 2006 | 02:12 PM
gao8302's Avatar
I dont want the body lift on there. I want all suspension. What do you guys think about these Mickey Thompson Baja Radial MTZ Tires. Does anyone have these any how do they like them.?
Rim Diameter (in): 16 in.
Tire Size: 315/75-16
Sidewall Style: Outline white letters
Tire Construction: Radial
Directional: No
Tire Diameter (in): 33.50 in.
Load Range: D
Minimum Recommended Rim Width (in): 8.00 in.
Maximum Recommended Rim Width (in): 10.00 in.
Tread Width (in): 9.80 in.
Section Width (in): 11.90 in.
Recommended Rim Width: 8.5 in.
Tire Size 1: 315
Tire Size 2: 75
Asymmetrical Tread Pattern: Yes
Tube Required: No
Belt Construction: Steel-belted
Tread Depth: 19/32 in.
Tread Ply Quantity: 6
Sidewall Ply Quantity: 3
DOT-Approved: Yes
Max Load Single (lbs): 3,195 lbs
Old Aug 20, 2006 | 04:26 PM
01-Z71's Avatar
That should look pretty mean. I have 265 75 r16's on no lift for now and what your talking should look alright.
Old Aug 20, 2006 | 05:49 PM
getchusum99's Avatar
my buddy has a 00 silvy z71 with a 6 inch suspension an 33inch
pro comp xterrain, i think it looks good.
Old Aug 21, 2006 | 05:57 PM
bggrnchvy's Avatar
Just take the body lift off and de-crank the keys a bit until you sit right up front for the tire size. then modify the leaf pack or remove the stock block out back to follow suit. A 6" decranked to 4" with 33's will look fine. I ran a 5" and 33's for a while on my OBS truck an it looked fine, but I still managed to rub if I really tried.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
