TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
tire size from front to back
Old Jul 6, 2014 | 08:54 PM
brizzle815's Avatar
Default tire size from front to back
So right now I have
265/65/18 front
275/50/17 rear drag radial
2" spindles in front
Not sure of rear drop but running all 4 tires same size truck is level.
Just curious if this reverse rake helps with traction. The new drag radials hook great but I don't want to keep them mounted all the time.
So I'm looking at saleing my 18s and re finishing 4 more 17" steel wheels. Buying set of new tires.
Just curious if anybody runs wide rear tire and a taller skinner tire in the front. Or do the heights need to be the same just run different widths.
Old Jul 9, 2014 | 12:08 PM
custm2500's Avatar
Ph.D. in HUBRIS
Rake will have little/no effect directly on traction. There is a reason why gassers are a design of the past.
ABS will be effected if you over all heights are too far off but other wise you will be fine.
BoostedBowTie
Jan 3, 2020 06:46 PM
Steve-O-08
Apr 19, 2018 09:32 AM
stealthperf
34
Feb 14, 2016 11:35 AM
askkmb
Jul 18, 2015 09:02 PM
jrplz
Jul 9, 2015 12:07 AM
