TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Tire question: P sized vs. LT sized
Old Oct 14, 2006 | 03:08 PM
alan2000T/A's Avatar
10 Second Club
Default Tire question: P sized vs. LT sized
I'm about to buy some 285/75-16s for my yukon. I have a Toyo connection so I want to use that. However, the "highway" Toyo Open Country HLs don't come in 285/75-16s -they do come in 265/75 and 275/70s.
The Open Country A/T comes in 285/75-16 but its an LT285 tire where my current tires are P265s. What difference will the LT make? It is a stiffer sidewall? I know the 285 is roughly an inch taller, but I wonder if the LT tire will be harsh?
Old Oct 14, 2006 | 04:46 PM
white1's Avatar
The P stands for passenger, and the LT stands for light truck. I think the LT is a tad stiffer sidewall, but Im not 100% sure.
Old Oct 14, 2006 | 07:36 PM
10 Second Club
I just want the 285s and in a Michelin you can get the P285 -I think, but in the Toyo it only comes in LT.
Old Oct 14, 2006 | 11:18 PM
white1's Avatar
You'll be fine
Old Oct 14, 2006 | 11:49 PM
truckmann's Avatar
LT will be a little stiffer and sometimes have a higher max psi rating. They also have a higher load rating. You will be fine with with either probably won't notice much of a ride difference between a P and an LT tire.
Old Oct 15, 2006 | 09:40 AM
04BlackGmc's Avatar
10 Second Club
truck its better to have a lt tire.
Old Oct 16, 2006 | 09:16 PM
COLDZ71's Avatar
P rated tires are 4 ply and LT rated tires start out at 6 ply and go up from there. If you are replacing a P rated tire with an LT it will ride noticibly stiffer.
Old Oct 17, 2006 | 12:40 AM
http://www.tirerack.com/tires/tirete....jsp?techid=46
Old Oct 17, 2006 | 02:28 AM
Blown02Sierra's Avatar
lt has higher load and psi rating. If you ever tow or put anthing in your bed, i would reccomend Light Truck tires.
Old Oct 17, 2006 | 06:32 AM
10 Second Club
Great info, thanks!
Stainless Works
13
Nov 5, 2015 03:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
HIDEXTRA
Jul 21, 2015 05:43 PM
jrplz
Jul 9, 2015 12:07 AM
