TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
sagging front end
Old Nov 21, 2006 | 11:15 AM
Default sagging front end
Im new to the whole truck thing and I would like to know How to raise front end on a 2000 3/4 ton silverado to keep it from sagging so much it looks terrible
Old Nov 21, 2006 | 11:27 AM
TXsilverado's Avatar
the front isnt sagging, the rear is cocked up so it can tow more. drop shackles will level the truck out. most of the guys here use the 2" drop shackles to cure it
Old Nov 21, 2006 | 11:30 AM
virgils4.85spd's Avatar
Default You can...
raise the torsion bars on the truck. This will make the front end sit higher.
Derek
Old Nov 21, 2006 | 11:34 AM
Derek
Ive been told this where are they at, and how do you do it
Old Nov 21, 2006 | 11:40 AM
beastmode's Avatar
Import Moderator
follow the bar that runs to your front arms back to this picture you cant miss em, see these bolts this guys crankin do the same then hit a bumpy *** road then go get your steering aligned
Old Nov 23, 2006 | 07:53 PM
I wouldn't use an impact unless you plan on maxxing the bars. Just jack up the front of the truck so both front wheels are off the ground and use an 18MM (if I remember right) socket and turn the bolt on each side an equal # of turns. On a 1/2 ton, 6 turns is about 1.25", on your truck it will probably be less turns. Let the jack down and bounce the front end a few times, take a side-to-side measurment and re-adjust if neccessary. Then go get an alignment.
Old Nov 23, 2006 | 08:19 PM
blake2kz71's Avatar
you can use the keys from a 1/2 ton truck and they will act like the ford keys on a 1/2 ton. i would only recommend this if your stock keys are maxed out though. you wont need an alighnment unless you go up more than an inch. also leave the driver side 1/8 - 1/4 higher. and definatley use an impact unless you have a similiar build to hulk hogan lol.
Old Nov 23, 2006 | 10:41 PM
Well, I guess I'm built like HH...I used a regular ratchet/socket to tighten mine on a truck in the Salt Belt, aka the Rust Belt, and it wasn't hard. The key is to jack up the truck to take some of the load off. I've seen guys break off the key bolts using impacts on trucks sitting on the ground...to each their own, though.
Old Nov 24, 2006 | 06:19 PM
blake2kz71's Avatar
lol its not too bad if the tires are off the ground but still a pain. just do what you feel like. iv used an impact everytime and never broken a bolt. (iv put the ford keys on 5 diff trucks.)
Old Nov 26, 2006 | 12:26 AM
UnrthdxDream's Avatar
i dunno just my experience but i can definately get more torque on a bolt using a socket wrench rather than an impact... but maybe thats just cause i am used to only having fairly budget impact/aircompressor combos....
zblee
63
Jun 10, 2023 01:25 PM
JordanH
Feb 28, 2017 07:22 PM
5.3Caprice
Nov 7, 2015 08:56 PM
vmaxpro
Aug 10, 2015 07:25 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
