TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
rear diffs vs the front
Old Dec 29, 2010 | 10:31 PM
20chevy01's Avatar
Default rear diffs vs the front
sry guys new to the forum so not sure on how this goes.. but i was wondering about the rear diffs not matching the front, 5.13s and the rear is the stock 3.73 bought the truck from a buddy that had just swapped out the rear end after it blew out. main question is will it mess anything up being locked into to 4 wheel with the different gear combo, going to get the matching 5.13 rear asap but for now just want to kno
btw 01 z71
Old Dec 29, 2010 | 10:37 PM
viciousknid's Avatar
Where's the Beef?
YES it will.
Both need to spin at the same speed. What is going to happen is your rear wheels will be spinning at a different speed than your front wheels which will be extremely hard on your entire drivetrain.
basically your truck will be fighting itself to move.
Old Dec 29, 2010 | 10:41 PM
20chevy01's Avatar
thanks man, thats what i kinda assumed but wasnt to sure, im working out some problems with the fuel system and then thats the next step
Old Dec 29, 2010 | 11:06 PM
Bigredmariner's Avatar
Yeah bad juju if you stick it in 4WD, get them both the same before engaging 4WD or you will have a lot more to fix.
Old Dec 29, 2010 | 11:58 PM
andrew383's Avatar
traveling mod
Yeah def no 4wd action untill the gear swap lol
Old Dec 30, 2010 | 12:41 AM
Atomic's Avatar
I have a gauge for that
The only time ive heard of using different ratios is in dedicated mud-bog trucks where they run different kinds of tires on the front and back and can easily spin at different speeds.
But in your case, dont do it.
Old Jan 1, 2011 | 03:34 PM
bighoss77's Avatar
best case scenario youll bust a u-joint or twist a driveshaft... worst case scenario your t-case chain will go SNAP!
Old Jan 15, 2011 | 10:36 AM
pkozera's Avatar
If you have the autotrac tcase it will go in and work somewhat and if it is the autotrac you wont break the chain or the driveshaft but will deff burn up the clutch pack in the case.
SLOPONY
20
Oct 18, 2016 06:05 AM
1bad2k
Aug 18, 2015 09:50 PM
vmaxpro
Aug 8, 2015 10:49 PM
brandon6.0
Aug 7, 2015 11:22 PM
