TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
please suggest a way to remove this plastic from hitch.
Old 03-26-2018, 12:49 PM
thebrain's Avatar
Default please suggest a way to remove this plastic from hitch.
what is currently attached to the hitch receiver a shin protector?
it has three sensors an is electrically connected w/ two wires. I think its a backup camera for the head unit.
I have been able to remove the sensor however the plastic insert is jambedup/rust dam near stuck inside there isn't anything holding it in but itself been hammering pry bars/ spraying w/ JB Blaster vice grip welded to slide hammer pullers cant get it to budge.
thanks TB
Attached Thumbnails please suggest a way to remove this plastic from hitch.-hitch.jpg   please suggest a way to remove this plastic from hitch.-06.jpg
Old 03-26-2018, 01:09 PM
FFDP's Avatar
Hole saw through the middle so the sides can flex in while you pry it out.
Or use a sawzal to cut it flush, then stick the blade inside and start cutting in the middle of each side to break it apart.
thebrain (03-26-2018)
Old 03-26-2018, 07:05 PM
thebrain's Avatar
I don't have a sawzal anymore since MacKeda boned me on there rechargeable batteries this a brand new sawzal and 4 other power tools less than a year old, I'll never buy Mackeda again.
I will start cutting plastic w/ what I have a hack saw blade and towel for handle.
good suggestion on cutting this thing out.
now w/ the spare tire out of the way I inserted the reciever inside the hitch from inside out and have been beaten on it w/ a regular hammer, to bad the mexican lawn people came to my area, now I have zero tools in my unlocked shed, where I usalley keep my BFH , I have the greasie taco eaters on surveillance footage entering my shed.
trying to beat this thing out.
Old 03-27-2018, 09:14 PM
Littlefield's Avatar
Well, there’s ******* of every nationality.
Old 03-27-2018, 09:32 PM
thebrain's Avatar
a thief is a thief.
build a wall and the rats will burrow under. then we shall flood the hole.they wont give up.
rant over, anyway I cut the insert w/ hack saw and beat it out.
next a trans cooler any suggestions.
Old 03-28-2018, 07:51 AM
TXsilverado's Avatar
A torch. Plastic and high heat dont mix.
Patrick Mclaughlin (02-25-2021)
Old 03-28-2018, 08:28 AM
thebrain's Avatar
actually I cut the insert w/ hack saw blade wrapped in rag and beat it out.
still havent found out what this comtraption is it has 3 sensors I think its a backup camera.
Old 03-28-2018, 09:32 AM
bobfig's Avatar
something like this
Amazon Amazon
Old 03-28-2018, 10:06 AM
thebrain's Avatar
yes that's the thing
so its not a backup camera
does it connect to radio and beeb when you are in reverse about to run over a object.
thanks
skolman91
09-07-2010 04:12 PM
chris04
05-04-2007 10:28 AM
TwoFast
04-14-2004 09:02 PM
1SlowT/A
17
06-14-2003 07:56 PM
Quick Reply: please suggest a way to remove this plastic from hitch.
