please suggest a way to remove this plastic from hitch.
2 Attachment(s)
what is currently attached to the hitch receiver a shin protector?
it has three sensors an is electrically connected w/ two wires. I think its a backup camera for the head unit. I have been able to remove the sensor however the plastic insert is jambedup/rust dam near stuck inside there isn't anything holding it in but itself been hammering pry bars/ spraying w/ JB Blaster vice grip welded to slide hammer pullers cant get it to budge. please suggest a way to remove this plastic from hitch. thanks TB |
Hole saw through the middle so the sides can flex in while you pry it out.
Or use a sawzal to cut it flush, then stick the blade inside and start cutting in the middle of each side to break it apart. |
I don't have a sawzal anymore since MacKeda boned me on there rechargeable batteries this a brand new sawzal and 4 other power tools less than a year old, I'll never buy Mackeda again.
I will start cutting plastic w/ what I have a hack saw blade and towel for handle. good suggestion on cutting this thing out. now w/ the spare tire out of the way I inserted the reciever inside the hitch from inside out and have been beaten on it w/ a regular hammer, to bad the mexican lawn people came to my area, now I have zero tools in my unlocked shed, where I usalley keep my BFH , I have the greasie taco eaters on surveillance footage entering my shed. trying to beat this thing out. |
Well, there’s wankers of every nationality. |
a thief is a thief.
build a wall and the rats will burrow under. then we shall flood the hole.they wont give up. rant over, anyway I cut the insert w/ hack saw and beat it out. next a trans cooler any suggestions. |
A torch. Plastic and high heat dont mix.
actually I cut the insert w/ hack saw blade wrapped in rag and beat it out.
still havent found out what this comtraption is it has 3 sensors I think its a backup camera. |
something like this
yes that's the thing
so its not a backup camera does it connect to radio and beeb when you are in reverse about to run over a object. thanks |
