TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Need a Lift? What would...
Old Jul 26, 2006 | 11:05 PM
SMcMahon's Avatar
Question Need a Lift? What would...
Need a lift? What would work best on my truck?
Rancho?
Superlift?
ProComp?
I have a 2004 all stock 4x4 ext cab.
Old Jul 27, 2006 | 11:23 AM
chuckie311's Avatar
depends on how high you want to go..
Old Jul 27, 2006 | 03:26 PM
mwalls54's Avatar
Need More N2O Mod
what size tire you wanting to run and how much you wanting to spend??
Old Jul 27, 2006 | 05:46 PM
gao8302's Avatar
You have a pm. Go with the skyjacker lift kit dude. Nothing else compares when it comes to these trucks.
Old Jul 27, 2006 | 07:58 PM
00Silverado's Avatar
Procomp is a 6" fulldrop kit, meaning the lca/uca and differential are dropped a full 6 inches. The Rancho is a knuckle lift, which leaves the upper control arms in the factory position, drops the lower control arms 6" and uses a longer knuckle to make up the distance. The differential on most knuckle kits is only dropped about 4.5 inches, which at factory settings will cause the cv's to be at an angle. Basically it all boils down to what size tire you want to run. 33" - Go with the Rancho. 35's - Go with the Procomp. The Superlift bracket lift is garbage, I've seen a uca drop snap after light offroad use. The Skyjacker I'm not a fan of.
Old Jul 27, 2006 | 08:04 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
You migtht want to check out FabTech. Quality parts but $$ you pay for it.
Old Jul 30, 2006 | 12:05 PM
SMcMahon's Avatar
Thanks for the input. I like the SkyJacker. And it looks like something I could do myself.
Old Aug 7, 2006 | 08:42 AM
01-Z71's Avatar
careful doing it your self with IFS, Ive lifted solid axle trucks in the past and they were a cake walk compared to IFS. I love the ride you get from IFS but solid is so much easier to work on.
Old Aug 7, 2006 | 09:31 PM
9GMC9's Avatar
Yea I dont really trust ProComp lifts, good tires though.
00loudchevy
Dec 3, 2015 05:54 PM
Jake75
Oct 2, 2015 02:28 PM
JoshH
Sep 28, 2015 11:19 AM
vmaxpro
Sep 28, 2015 11:10 AM
zblee
Sep 19, 2015 06:33 PM
