Need a Lift? What would...
Procomp is a 6" fulldrop kit, meaning the lca/uca and differential are dropped a full 6 inches. The Rancho is a knuckle lift, which leaves the upper control arms in the factory position, drops the lower control arms 6" and uses a longer knuckle to make up the distance. The differential on most knuckle kits is only dropped about 4.5 inches, which at factory settings will cause the cv's to be at an angle. Basically it all boils down to what size tire you want to run. 33" - Go with the Rancho. 35's - Go with the Procomp. The Superlift bracket lift is garbage, I've seen a uca drop snap after light offroad use. The Skyjacker I'm not a fan of.
