TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Need advice for "Welding Rear End?"
Old Nov 2, 2008 | 02:11 PM
Exclamation Need advice for "Welding Rear End?"
So yesterday I was drinking with some buddies. i was talking about how I finally ordered my gears for my blazer after breaking the stock 3.08"s. One of my buddies said he once broke his ring teeth on his jeep and he just welded the ring and pinion. He recommened that I could do the same until i save up to get the gears for the front axle. Is it possible to "Weld the ring Gear" and It will be a Posi? WTF? Or did my buddy have to much to drink? Thanks
Old Nov 2, 2008 | 02:19 PM
cheyenne383's Avatar
TOWN CRIER
He was drinking too much... the only welding you can do inside the centersection is the spider gears inside the differential which works like a spool and gives equal power to both wheels. This isn't a good idea for offroad vehicles due to the amount of twist and lateral force they see and the heavier tires usually involved.
Old Nov 2, 2008 | 02:28 PM
Yeah I didn't think it was a good idea! Thanks for the info. I don't know much about rear ends.
Old Nov 3, 2008 | 09:08 AM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Theres nothing really wrong with welding the rear, if done right it will be very very strong, but as cheyenne383 said you dont weld the ring and pinion only the spiders
Old Nov 3, 2008 | 10:48 AM
So even if i did weld the spiders I would still need to replace the ring and pinion right? since I broke the teeth off those. So in other words welding the spiders just makes it like a spool by locking up both tires?
Old Nov 3, 2008 | 10:52 AM
nonnieselman's Avatar
yea, you have it... the spider gears are now locked together by a weld.. So only way one tire is goin to spin with out the other is, if you broke an axle, broke the spider gear or something worse.
My brother welded the spider gears in the front of his 77 Chevy. 3k rpm dump in 4L kinda killed it. broke the spider gears in half where the welds were..
Old Nov 3, 2008 | 01:14 PM
outlawz2004's Avatar
They have a how to article in the latest Petersons 4 wheel and off road magazine. I did this on an old mud truck. It eventually crapped out .
Old Nov 3, 2008 | 01:39 PM
haha so did my brothers.. we put a some more spider gears in it.. and its workin fine
Old Nov 8, 2009 | 08:20 PM
slowrollin93's Avatar
I have seen plenty of welded rearends hold up. Even a camaro run a 7.3 pass in the 1/8th with slicks and welded spiders. Its all in who welds it, if they know what they are doing, and how much of the gears they actually weld. I wouldn't be affraid to do it unless it was a daily driver, it just sucks in parking lots and stuff when your turning but then again my detroit locker is a pain in the butt sometimes too.
Old Nov 10, 2009 | 12:52 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Lincoln Locker.
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
