TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
how much lift to clear 35"s
Old Nov 14, 2010 | 09:03 PM
LS1TRUCKGUY's Avatar
Default how much lift to clear 35"s
im possibly looking to buy a ccsb 4x4... how much lift is needed to clear a 35" tire lock to lock without rubbing? i dont mind trimming the lower valence if needed, but i dont want them rubbing on anything else. the reason is, i am going to be pulling the tires off my diesel when i get rid of it, and plan on using those since they are almost brand new. im looking at nbs and nnbs trucks. thanks in advance
Old Nov 14, 2010 | 09:33 PM
sleepersilverado's Avatar
kind of ironic. me and you are doing the same thing but completely opposite. I am going to be getting rid of my 07 nnbs ccsb with 35's and get a new 6.7 power stroke. I am also going to pull my 35's off to put on the new truck.
I have a 3" lift. I am not much for big lifts, i like stuffing the tires. I had to cut the bottom back of the fender were the mounting bolt is. You can not tell looking at it and then had to stretch the inner plastic wells. I dont think this combo will work with aftermarket wheels.
Old Nov 14, 2010 | 09:36 PM
pewterliftedz's Avatar
a 6in lift will clear 35s lock to lock and with some flex.
i used a 3" body lift and leveling kit on my 2000 to clear 315/75r16's. but if i flexed it hard enough it would rub.
Old Nov 15, 2010 | 02:10 PM
thats pretty ironic. lol
do you have any pics?
Old Nov 19, 2010 | 05:27 PM
Hey man I hope this helps you out.
Old Nov 19, 2010 | 05:46 PM
Bumpers's Avatar
Depends one backspacing width what kinda lift etc.. I could rub 35s with 10" of lift if I wanted too..
What model is the truck ? The nnbs doesn't clear as good as the nbs either
Old Nov 19, 2010 | 08:08 PM
dlt76028's Avatar
I hate chevys square fender wells....
Old Nov 19, 2010 | 10:56 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Get cutout flares and run negative offset wheels.
Old Nov 20, 2010 | 12:48 PM
im looking at both... nbs and nnbs... if i get a nnbs with factory 20's,i will use those with some spacers. the tires are 325/60/20 terra grapplers
Old Nov 20, 2010 | 03:27 PM
Bumpers's Avatar
If I were you if you go with nnbs truck get the fabtech kit.. And nbs just pick one besides fabtech
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
cheyenne383
Nov 13, 2015 09:24 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
vmaxpro
Sep 28, 2015 11:10 AM
