TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
HELP Leveling kit install
Old Dec 9, 2006 | 09:23 PM
carbonz71's Avatar
Default HELP Leveling kit install
I just finished installing my leveling kit I got from offroadunlimited.com with the new tb keys and shocks. Problem is I put hte new keys in and put the adjuster bolts back to the same position and the front is 1 inch taller than the rear. I loosened the tb adjuster bolts some to try and lower the front but how must can I loosen them and be safe? I did 6 turns and it only has gone done 1/2 inch????
Old Dec 9, 2006 | 09:48 PM
munchman's Avatar
i have my adjustment bolt where only 3 or 4 threads are thru the block in the cross member. imo i would leave it about an 1in high because the keys will settle some in time
Old Dec 9, 2006 | 09:58 PM
mwalls54's Avatar
Need More N2O Mod
yeah drive it around a little bit and let the suspension work a little bit. i always find going over speed bumps work the best. then if its still higher then loosen the bolts some. i wouldn't loosen so much that the key is resting on the block. always leave enough bolt sticking out so that the key rests on the bolt.
Old Dec 9, 2006 | 10:15 PM
carbonz71's Avatar
I loosened to where there is about 1/2inch of threads between the block and tb key and its sitting level now. I will just have to check it again after driving around tomorrow. Do you think an alignment is neccesary if it still drives straight after the install.
I drove it a little after instaling and was suprised the ride is exactly the same as stock when I simply cranked the stock bars I noticed the ride stiffen up before.
Old Dec 16, 2006 | 06:18 PM
kelchie's Avatar
Does that kit raise it up 2 inchs + some if you crank that down... What im trying to ask is whats the diff between those and my cranked up stock ones? Looking into this kit. Thanks
Old Dec 18, 2006 | 10:14 AM
carbonz71's Avatar
I installed the kit whith the 4 new shocks and it rides very close to stock. I previously had the tb cranked and the ride was rougher but i installed the new keys and the ride was much better. I drove it around for a week before I put on the longer shocks and the ride was ok with the stock shocks. It was very easy to install with the GM torsion bar clamp. The only problem was I thought I was getting the Bilstein shocks that are shown on the pic of the kit but they dont use bilstein anymore someone told me they are the edlebrock shocks. Overal I like the kit because the ride is virtually the same as stock, if I were to do it again I would probably just get the keys and get shocks from any brand you like.
Choda
Jan 22, 2026 02:03 PM
thunder550
Oct 8, 2015 04:53 PM
Dezert1500
Jul 30, 2015 02:51 PM
therock
Jul 25, 2015 09:23 AM
