TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Air bag setups (for towing)
Old May 30, 2012 | 03:21 PM
  #31
nonnieselman's Avatar
Sensors?
Old Jun 1, 2012 | 03:18 PM
  #32
KIFER88's Avatar
yah mines got a sensor wire going to each rear wheel.thunk it has to be for the abs/stabilitrac junk.. if everyhtung was the4 same id go for the 14b instead of regearing..
Old Jun 2, 2012 | 10:27 PM
  #33
andrew383's Avatar
traveling mod
Ben which kit did you have when you almost broke the frame??
Which is going to be the better mounting option in/outside the frame rail??
Old Jul 24, 2012 | 12:52 PM
  #34
KHester84's Avatar
How much room do you have between the bigger mud tires and the bag/mounting bracket? Just curious if this setup will work with the 325/60s I have on my truck. Nice truck!
Old Jul 24, 2012 | 01:14 PM
  #35
Has anybody ever put your truck on a car lift and noticed the space between the cab and bed get bigger?
It does the same thing if i put a heavy tonge weight trailer on it also..
No cracks in the frame or anything that i can find.
Old Jul 24, 2012 | 01:24 PM
  #36
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
My tires clear by atleast 2" with a 0 offset.
Never had mine on a lift but that gravel load had a lot of tongue weight and I didn't notice any excessive gap.
Old Jul 24, 2012 | 03:11 PM
  #37
custm2500's Avatar
Ph.D. in HUBRIS
I have my Tahoe bagged with firstone 2500 bags and it rides great and hauls anything you can possibly put on the hitch. I have pulled 5-6 ton on a two axle trailer. I have posted the pics a few times.
Here is a brand new 2012 eco boost wih air lift helper bag systems.
That is a 2500 lbs. tote in the bed. We haul tires all the time and the guy who drives the truck doesn't have a complaint about them.
If you tow or haul anything more then a few hundred pounds in your truck you are a fool to not install air bags. It keeps your alignment correct and safe.
Old Dec 12, 2012 | 10:08 AM
  #38
splinter's Avatar
Got them installed tonight...
Thanks for your valuable tech in this thread. Mine are on their way…and I just saved $0.22!
Old Dec 12, 2012 | 10:21 AM
  #39
i always keep 5-10psi in my bags just to keep them blown out and straight.
Old Dec 12, 2012 | 11:36 AM
  #40
custm2500's Avatar
Ph.D. in HUBRIS
I belive it is recomended that 10 psi is the minimum you ever run. Maybe 5 is considered ok but the key is never every let them run flat. You can ruin the bags fairly easy.
