TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
37's with 6 inch and bigger keys?
Old Dec 20, 2010 | 09:41 PM
Y@ BoY p@Ul's Avatar
The wheels i got got noe 18x9 and almost factory back spacing. And i plan on running like a toyo mt or a micky thompson mtz or just go back to grapplers like i have now. Well i've already got bigger keys and my ride isnt that bad so i think im just going to stick with the 6 inch cut some if i even have too.
Old Jan 4, 2011 | 05:22 PM
aeorozco's Avatar
Originally Posted by zachm89
I'm just saying that going with a 2 or 3" body lift rather than cranking up the torsion bars would be a lot better for your on road ride quality. Any messing with the torsion bars will make your ride quality go to crap. 37s with say a fabtech 6" lift and 2" body lift would fit perfectly and ride much better thank cranking up the torsion bars.
Agreed, I am in the same boat and if you are looking to lift 6" plan on spending about 5k with new rims and tires, shocks and the lift. You can get the same "stock" ride with your lift if you do not mess with the TB's .
Why spend the 5k for a 6" lift when you can put on a 2" body lift($300) and buy a 4" suspension lift($800-1000) for half the cost and it saves your ride quality.
Old Jan 9, 2011 | 01:18 AM
Well im plannin on sellin my 98 chevy and using all that money to go for buyin my lift,wheels, and tires. And i was really kinda thinkin a 6" lift with a 2" body lift and maybe even runnin 38's if i could. Butlike everything else, just gotta wait and see what happens lol
Old Jan 10, 2011 | 11:58 AM
pkozera's Avatar
Look at the sig these are a 385 nitto on 8 inch rims. 6 inch rcx 3 inch bod and keys and the fronts are ok but hit in the rear when off road it now has a fleetside bed so i can run bushwacker flares and should be ok off road. I did have a 39.5 irok on there also and still cleared on the front.
Old Jan 12, 2011 | 12:40 AM
I just wanna say thank ya'll for all tha help. But i think im still going to do the 6 inch skyjacker stage ll. But i might end up puttin a body lift on. If so whats some that ya'll have had the best luck with ?
Old Jan 12, 2011 | 07:05 PM
For a suspension,you should also check out BDS Suspension.
6.5" Hi clearance design for the 1500's are nice.Torsion bars stays at the stock location.
Old Jan 13, 2011 | 09:39 AM
pkozera's Avatar
RCX also makes a 6 inch with a no torsion bar drop and they are alot cheaper than most others i paid under 1000 for my 6 inch.
Old Feb 23, 2011 | 09:43 PM
getchusum99's Avatar
i would reccomend the bds or rcx also. great quality and ride in both. ive installed 2 bds lifts on silvys and had great results, pretty easy as well. leave the keys alone.
$A_Money$81
Mar 27, 2023 10:25 AM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
CD82
Oct 23, 2015 07:32 AM
old motorhead
Sep 29, 2015 08:22 PM
