TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
scan tool
Old Apr 12, 2011 | 12:20 AM
6789olds's Avatar
Default scan tool
whats a good scan tool that will retreve codes and read stuff like water temp and converter lock uo and stuff like that ?
Old Apr 12, 2011 | 12:26 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
http://www.aeroforcetech.com/
How in depth of a tool are you looking for? The aeroforce scan gauge will display almost everything the pcm controls, and also read & clear codes. If you need more than that, I can give you a better recommendation.
Old Apr 12, 2011 | 07:47 AM
6789olds's Avatar
is that more in depth then the scan gauge 2 ? because i have a scan gauge 2
Old Apr 18, 2011 | 02:31 PM
budhayes3's Avatar
PT's Slowest Truck
If you're looking for an inexpensive scan tool to retrieve/clear codes and view live data, there are a lot of options available for $200 or less. I have an Equus Innova that is capable of Can OBDII and ABS for Chevy, Ford, and Dodge...it's in their 3100 series, I believe that it is the 3160 (can't remember at the moment and the scanner is down in my truck)
http://www.amazon.com/Equus-3160-Pro...3154773&sr=8-1
It will also let you know if your monitors have run so you can go to state emission inspection and be sure not to fail for Emissions Monitors not being ready. I have an intermittent check engine light (P0446) for a faulty evap vent valve that I haven't replaced yet, and I was able to clear the code and drive around until all of the monitors ran and passed, and go to inspection and pass. Now I have another two year reprieve until I have to replace the vent valve
Old Apr 18, 2011 | 08:54 PM
6789olds's Avatar
i do that with my daily driver its a lumina . takes 31 miles for the light to come on so i drive 10 miles then go smog it lol
Old Apr 19, 2011 | 10:22 AM
budhayes3's Avatar
PT's Slowest Truck
LOL, whatever it takes
Mine is the 3160 BTW, I'm very happy with it
Old Apr 19, 2011 | 12:41 PM
joehawkz71's Avatar
Does that scan transmission stuff as well..
Old Apr 19, 2011 | 12:43 PM
nonnieselman's Avatar
I got the scangauge2 and it works great.
It dont do Converter clutch lockup but it does do Trans Temp.
Old Apr 19, 2011 | 12:50 PM
budhayes3's Avatar
PT's Slowest Truck
It will display OBDII generic data, and transmission P codes, but won't show when solenoids are activated, tcc engagement, trans temp, etc.
I also have an old AutoXray scan tool that I basically use just to check for knock retard, as the 3160 doesn't show that info. I haven't checked, but I'm sure that there is a GM Enhanced flash update available, as the scan tool came with a disc and USB cable. That's how I ended up with KR scanning capability with my AutoXray, which also only displayed OBDII generic data. The AutoXray that I have has a small screen and only displays one parameter at a time...it's a bit of a PITA. The Equus Innova 3160 has a nice size screen and displays a bunch of data at once, and is extremely user friendly
JordanH
Dec 25, 2015 08:32 AM
JordanH
Oct 11, 2015 05:27 PM
69z-28
Sep 21, 2015 07:31 AM
muncie21
Sep 7, 2015 09:55 PM
LT-1 SS
Sep 3, 2015 07:31 AM
