TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
3M Roloc Pads
Old May 20, 2012 | 04:38 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default 3M Roloc Pads
What size and grit is everyone using for cleaning blocks and heads? I need the pads and the drill mount too.
Old May 20, 2012 | 06:55 PM
03sierraslt's Avatar
You can use surface prep discs too, Blue, Red and Brown. Blown is the most aggressive. I Like 2" but for large surfaces usually go with a 3"
I prefer surface prep over sanding disks because surface preps wont take away too much metal unless you are trying.
Old May 20, 2012 | 06:57 PM
SCREAMINXL's Avatar
I use the 80 grit on cast iron.
Scotch-Brite
and the 120 grit on aluminum and cast iron.
Scotch-Brite
I use a 2" holder like this one.
3M Roloc Disc Pad Assembly 05539, 2 inch
This has always worked for me. The 50 grit bristle removes lots of material! I used one to sharpen my lawn mower blade!
Old May 20, 2012 | 07:01 PM
1slow01Z71's Avatar
Sorry, shouldve been more clear, Im looking for the bristle type. I used to have one a long time ago but it wore out long ago. Mine was 2" too but didnt know if a 1" or 3" is better. It will be used for cleaning the block and heads, on head swap/motor builds. Ive been using a razor blade very carefully, terry cloth and brake cleaner. The roloc pads are much easier so Id like to get them again for the next two motors Im building.
BlackGMC's Avatar
Resident Retard
I use the yellow ones.
Old May 20, 2012 | 07:29 PM
SCREAMINXL's Avatar
I posted the bristle type. Green = 50 grit, Yellow = 80 grit and White = 120 grit. Are you looking for a place to purchase these?
I use them in the 2" size also, but really like use the 3" disc with a 2" holder. I feel like I have more control and can apply more/less pressure on the outside 1/2" that's not supported.
The 1" disc almost seem useless and I have found little use for them yet.
Old May 20, 2012 | 07:34 PM
A Low Dime's Avatar
13 Second Truck Club
Do the cheap ones work as well as the 3M branded?
SCREAMINXL's Avatar
These are my favorite too.
Old May 20, 2012 | 07:42 PM
I got some of those too but I cant recall where I got them from.
Old May 20, 2012 | 08:46 PM
1slow01Z71's Avatar
I was replying when you made your reply.
Best Ive found is on ebay 35 for 5 of the yellow and 50 for 5 of the white in 3". That just seems really steep to me. Are they just that expensive or is there a cheaper place to get them?
