Texas We've Seceded from the Union
RIP Transmission... 4/24/2010
Old 05-06-2010, 06:17 AM
  #31
jg53's Avatar
wait scratch that. i remember when he sold them. im losing it over here.
Old 05-06-2010, 01:18 PM
  #32
03 True Fire's Avatar
Originally Posted by 1-87 chevy
when will the truck be ready ? i'am still down to run let you have a rematch with the old school , let me know when, and will take them out and see how the new mods perform.
haha well i got a lot going on right now so the truck is on the backburner for now.. havent touched it in a couple weeks but i'll let you know when i get her back! were defintely going to have to line them up again! i want a rematch! haha
Old 05-06-2010, 04:27 PM
  #33
i wanna play!!!!
Old 05-06-2010, 05:18 PM
  #34
stevenc's Avatar
Originally Posted by pasadenaman
Just a quick suggestion, I know that performabuilt does not post all that goes in the tranny. See if you can find out if they install an Input Drum Support Ring
(hardened reinforcement drum sleeve & Piston kit) &
You can get spider cracks on drum at shaft area which are caused by hard 1-2 shifts, high torque or heavy vehicle. The kit is $49 and a cheap add on worth the money.
I am sure they use Aluminum accumulators intead of the brittle plastic ones. One last thing, have them use a torrington bearing instead of a stock one to better protect your planets.
If you get the support ring you will also need this $60 Short Inner Race and included the Torrington Bearing for the above Sonnax Input Drum Support Ring kit. If that bearing goes out, your planets are toast. Or at least just get the Torrington bearing.
As far as I know they do not install the sleeve. I talked with them and they said they have not found any higher failures without the sleeve as with the sleeve. Some people use them some people don't. *shrug*
To bad it doesn't help with a failure like this: http://img690.imageshack.us/img690/8...nsmission3.jpg
Old 05-08-2010, 09:03 AM
  #35
FLT
FormerVendor
FLT's Avatar
I personally like the sleeved drum with a billet over run piston and a steel bonded forward piston. I have seen many shafts float in drums causing failures over the years. When I build units I always check to see if the input shaft is good n tight in the drum whether a sleeve is used or not. With the weight of a truck that input drum needs all it can get. I say get a sleeved drum. Just the other day I threw three nice looking drums away because the shafts pressed out easy. With that being said how long will it take before it starts to float? Just my 2 cents. Vince
1slwgto
10-01-2015 01:51 PM
MOBBN
09-22-2015 08:07 PM
Offroadunleashed
07-20-2015 02:25 PM
Riceconvert5.3
01-20-2005 07:55 PM
BigTex
24
12-13-2002 07:55 AM
Quick Reply: RIP Transmission... 4/24/2010
