Texas We've Seceded from the Union
4l80e install
Old Dec 28, 2009 | 10:27 AM
Coban's Avatar
Default 4l80e install
How much would someone want to help me install this sucker? I would actually be helping you since you would hopefully be more experienced....
I have everything for the swap, but I've never seen the thing run. So, if it doesn't, the 4l60e will have to go back in... I dropped the pan and everything looked good (to me). It was from a wrecked truck.
Old Dec 28, 2009 | 04:10 PM
Camaro Zach's Avatar
Do you have a list of all the parts you have? I might be able to work something out.
Old Dec 28, 2009 | 06:24 PM
Coban's Avatar
Tranmission
Dipstick/tube
Cooler lines for 2500 suburban (per kysilverado's thread)
Modified crossmember
2nd VSS harness
...diagram for main harness
Conversion yoke
Stock U-joint
4l80e flexplate w/ bolts
4l80e TC w/ bolts
Segment swapped file (I have hptuners)
No cover for now.
Old Dec 28, 2009 | 07:50 PM
one03sierra's Avatar
Formerly one92rs
well i see you have the crossover already. when i did mine back in the day i cut out the 60e ears. i then took a 3/4 ton crossmember and cut it down. the drilled and mounted it that way. a transmission jack would help you out a bunch.
Old Dec 28, 2009 | 08:53 PM
Coban's Avatar
02denali, I can't even count the number of people I have showed your wind noise fix for the extended cab windows.
I thought about doing the crossmember that way, but I actually had an extra 1500crossmember laying around.
Old Dec 29, 2009 | 08:26 AM
Tootall's Avatar
Zach did his in about a day.
He's a great metal fab guy too . . . no worries
. . . I hear that he can pull an 80e and swap converters pretty quickly too . . .
Old Dec 29, 2009 | 09:07 PM
sixltrbtr's Avatar
Sorry to get off subject but what's the fix for the wind noise?
Old Dec 30, 2009 | 07:26 AM
Coban's Avatar
search for kysilverado and "wind"
Old Dec 30, 2009 | 01:32 PM
v8
17,16,15,14,13,12,11 Drvr
Lance(02denali)know exactly what to do lol
zblee
Aug 3, 2015 03:45 AM
lycominghunter
Jul 29, 2015 04:24 PM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
black6spdz
Jul 16, 2015 01:32 AM
