4l80e install
How much would someone want to help me install this sucker? I would actually be helping you since you would hopefully be more experienced....
I have everything for the swap, but I've never seen the thing run. So, if it doesn't, the 4l60e will have to go back in... I dropped the pan and everything looked good (to me). It was from a wrecked truck.
Tranmission
Dipstick/tube
Cooler lines for 2500 suburban (per kysilverado's thread)
Modified crossmember
2nd VSS harness
...diagram for main harness
Conversion yoke
Stock U-joint
4l80e flexplate w/ bolts
4l80e TC w/ bolts
Segment swapped file (I have hptuners)
No cover for now.
Dipstick/tube
2nd VSS harness
Conversion yoke
Stock U-joint
4l80e TC w/ bolts
No cover for now.
well i see you have the crossover already. when i did mine back in the day i cut out the 60e ears. i then took a 3/4 ton crossmember and cut it down. the drilled and mounted it that way. a transmission jack would help you out a bunch.
02denali, I can't even count the number of people I have showed your wind noise fix for the extended cab windows.
I thought about doing the crossmember that way, but I actually had an extra 1500crossmember laying around.
zblee
Aug 3, 2015 03:45 AM
lycominghunter
Jul 29, 2015 04:24 PM
lxcoupe
Jul 21, 2015 02:12 AM
