TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
Installing 06 Chevy E-fans on a 01 Chevy
Old Jul 12, 2017 | 10:56 AM
  #101
ss4chad's Avatar
12 Second Club
Does the Model of the truck matter for the Headlamp Wiring Harness? I am installing the e fans in my '03 GMC 1500, I have found several harness's out of 2500 and 3500's, would they still work?
Chad
Old Jul 12, 2017 | 11:10 AM
  #102
ss4chad's Avatar
12 Second Club
Originally Posted by obukev
Been doing research and calling every salvage yard to find a factory harness (GM Part# 15912597).... hard to find.... at least here in Oklahoma. I have a list here of search results on car-part.com ... Search term to use: Headlamp Wiring Harness with year range 2005 to 2007. Give these a try but make sure you ask if the harness has the efan portion of the harness incorporated.
Had my tune done for e-fans at D&G Dyno Tune in Hennessey, OK. Great customer service, very affordable, and knows the questions to ask to get your tune done right. Simply cannot go wrong with Dwayne.
Whats the difference between GM 15912597 ($436.47) & GM 15187415 ($190.85) wiring harness? Other than the price obviously, is there something significantly different like an extra plug, fuzzy tape wrap, relay attached, etc...?
Chad
Old Jul 12, 2017 | 11:19 AM
  #103
ss4chad's Avatar
12 Second Club
And what if it came out of an Avalanche?
Chad
Old Jul 12, 2017 | 10:05 PM
  #104
1FastBrick's Avatar
Custm2500's Rude Friend
You need the headlamp harness out of a 1500 series Truck or SUV from 2005-2007 classic that was equipped with Fans.
Old Jul 29, 2017 | 09:23 AM
  #105
ndollar1's Avatar
Question.. just did the swap on my 03 silverado followed the instructions per a instruction sheet from Retrofit electric fan kist lsxjustchevytrucks.com anyway they state to use green to pin 42 on C1 and the blue wire into pin 33 on C2. It stated if a wire was already in pin 33 on C2 to remove and place to side. However after doing that I have no a/c I believe that was a clutch trigger wire. thoughts? was tolds to tap into other wire. would like to avoid that
Old Sep 1, 2017 | 01:40 PM
  #106
Nasty02Tahoe's Avatar
What size relay should I use when tapping in to the green A/C wire in the factory harness
Old Sep 1, 2017 | 01:59 PM
  #107
ScottyBoy's Avatar
I used a basic 30amp relay on mine, and it's been fine for many years now.
Old Sep 1, 2017 | 03:56 PM
  #108
[QUOTE=ScottyBoy;5418166]I used a basic 30amp relay on mine, and it's been fine for many years now.
thanks I have the green wire pinned to 42 and just wanted to make sure on the relay before I spliced in to the green wire on the fuse panel
Old Sep 1, 2017 | 08:07 PM
  #109
[QUOTE=Nasty02Tahoe;5418174]
scotty I found a 40 amp relay in my tool box would that be to big
Old Sep 9, 2017 | 11:02 AM
  #110
ScottyBoy's Avatar
Yes, a 40 amp relay will be just as fine.
