Where is the best place for power?
Old May 3, 2008 | 10:47 PM
Ron's5.3's Avatar
Figured I'd help with this one also.
C8 has different pins available for different conditions. It is also on the panel by the left foot. Upper left corner connector. You might not have anything connected there.
Pin A-Hot at all times-30Amp Seo 2 fuse
Pin C-hot in run/start-10 amp Seo ign fuse
Pin d- hot in accy/run- 10 amp seo acc fuse
Pin E- hot at all times-15 amp seo b1 fuse
Pin F is ground
Available at Mouser electronics for about $1 for connector then you need a couple 280 metri pack female pins. Might be able to get from GM.
Hope it helps.
Corvette454l88
Sep 1, 2016 01:24 AM
GMCtrk
Dec 18, 2015 04:47 PM
dry_kill
11
Aug 28, 2015 09:53 PM
Stainless Works
Aug 7, 2015 10:08 AM
Three6GMC
Aug 3, 2015 07:53 PM
