Dimming light wire for gauges
Old Apr 26, 2008 | 07:53 PM
BigCountryx's Avatar
Default Dimming light wire for gauges
whick wire are you guys tapping to be able to dim you're gauge lights along with you dash lights? Or, should I just wire it and not worry about diming?
Old Apr 26, 2008 | 08:05 PM
nightrunner's Avatar
Mr. Obvious
i tried two different wires but still couldnt get them(aftermarket gauges) to dim so i said screw it. i only had one that i could dim anyways my others are LED-lit and it was a autometer ultra-lite with the incadescent bulb in it and its not too bright. but i never use the dimmer on my dash lights anyways.
i know for sure that on a 01 its NOT the purple wire behind the headlight switch
Old May 2, 2008 | 01:38 PM
53RUSSELL's Avatar
post #11
https://www.performancetrucks.net/fo...cements&page=2
Old May 3, 2008 | 10:31 PM
Ron's5.3's Avatar
Have been looking a wiring diagrams for mine tonight for lighting up my switch panel. I am going to tap into the i/p relay center by your left foot. I have a 2004 and I know they changed that panel, I think in 2003, so these places should work.
C10 pin F is a dimming wire for incandesent lights(not LED's)- should be a brown wire with a white stripe. It is the big connector on the left looking at that panel. Second row from the left at the top.
C5 pin f is also a dimming connection- Mine has nothing there, so might tap in there if I can get the connector.
I tested C10 and it dims my panel.
If its an LED its in a different location.
Hope it helps.
Old May 3, 2008 | 10:43 PM
02BlueStepside's Avatar
Originally Posted by 53RUSSELL
Thats the one I used
Old May 4, 2008 | 01:33 AM
blue 01's Avatar
On an 01 there is a fuse in the drivers side dash fuse panel that says Illum. You can add a little fuse and Piggy back off it.
Wait maybe I used hat one to activate my Dakota Digital auto dim. Give it a test with a voltage meter. I can't remember.
ARC
57
Feb 21, 2022 10:54 AM
Corvette454l88
Sep 1, 2016 01:24 AM
slowmo934
Sep 9, 2015 12:24 PM
