Weird Electrical Problem, Would Like Some Opinions
Old Jul 23, 2008 | 05:35 PM
thunder550's Avatar
High on diesel fumes
If I'm reading it right, you have the G401 ground setup. Here's that one as well.
Old Jul 23, 2008 | 05:40 PM
thunder550's Avatar
Instrument panel
Old Jul 23, 2008 | 06:03 PM
KySilverado's Avatar
I've read about LED Third Brake lights causing problems you are describing. Something about them going to ground. Think I read about one or two posts here. Unhook it and see?
Old Jul 24, 2008 | 06:12 AM
Holty's Avatar
Notorious BIG
Thanks for the replies and the schematics, i'll post back with my findings.
Old Jul 24, 2008 | 11:16 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Holty
yes, the back up camera is activated when the gear selector is in Reverse.
If it's wired directly into the reverse light harness in the back of the truck, I'd check there first
Old Jul 24, 2008 | 12:48 PM
dewmanshu's Avatar
Moderately Differentiated
LOL @ Holty and schematics
Old Jul 24, 2008 | 02:05 PM
THE-HOE's Avatar
I had the same problem with my turnsignals, my horn quit working too. I started searching grounds and found a lose ground on the driver side radiator support. Its up past the rubber mount facing the front of the vehicle. i cleaned it up and tightned it down and the trunsignals worked fine. so check that one out
Idryfly5
Sep 2, 2022 08:55 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
mikeyjm1
17
Oct 29, 2015 11:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
