w/t fog light install.
Old Feb 12, 2014 | 01:52 PM
sierra69's Avatar
Cool w/t fog light install.
Hey guys i'm trying to install fog lamps on my 07 nnbs sierra w/t and is not pre wired for this install so my question is, should i buy a factory harness? or build my own? I already installed the housings and bulbs and new switch.
Old Feb 12, 2014 | 02:05 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You need a head light harness that is pre wired or the factory accessory kit to install the fog lights but I don't think they sell the add on harness separately.
You can make your own and tie it in to the fuse block like the factory does. You just need the fog lamp plugs and the pin locations in the fuse block under the hood.
Old Feb 12, 2014 | 02:11 PM
1FastBrick's Avatar
Found this aftermarket harness on Ebay. GMC Sierra Pickup Fog Light Wiring Harness Kit 2007 to 2013 | eBay
Not sure how good they are quality wise but may save you time.
Old Feb 12, 2014 | 02:59 PM
javzh's Avatar
wow that ebay harness is expensive
just make one yourself, its pretty simple.
you can either buy the 5202 connectors or use HIDs. http://www.ebay.com/itm/2-PCS-5202-H...-/121198281908
HOW TO: Make your own NNBS foglight harness - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
Old Feb 12, 2014 | 03:12 PM
1FastBrick's Avatar
Seeing as how the OEM kit for 07-13 is around $300 and he already has the other parts I would do the same.
Just need to find the part number for the Pin under the fuse block.
The 07-13 factory GMC fog lamp kit is PART # 19170447
Old Feb 12, 2014 | 03:22 PM
1FastBrick's Avatar
I came across another thread that showed you could by the front lamp harness that has fog lamps wired in for the 07-08 from GM under Part number 25866139
T96 was RPO code for the fog lamp option.
Old Feb 12, 2014 | 05:51 PM
Three6GMC's Avatar
I added a couple fog light kits to some friends trucks and I just went the factory route. Want to say it was around $300 per kit but thats including the fog light housings factory harness and DIC panel switch. They plug and play super easy and look factory when done. Cant beat the look of OEM, but thats just me I don't really like seeing random switches and relays mounted everywhere.
Old Feb 12, 2014 | 06:21 PM
javzh's Avatar
^ agreed. when i did my friends i bought the oem switch 25858705. the only thing not factory in the install was the harness i made.
Old Feb 12, 2014 | 08:24 PM
sierra69's Avatar
Well an ex-co worker who works at a gm dealership just found me the harness for $80 bucks so i guess i will go that route since that all i need.thx guys!
Old Feb 12, 2014 | 08:43 PM
javzh's Avatar
just the fog light harness or the whole front electrical hanress part number 1fastbrick posted?
if just the fog light harness, do you have a part number for future reference?
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
bearden86
26
Nov 15, 2015 03:58 PM
cheyenne383
Nov 13, 2015 09:24 AM
carid
Oct 1, 2015 09:22 AM
