Time for new speakers, What should I get?
Old Mar 12, 2018 | 10:54 AM
  #31
ILuvJDM's Avatar
Originally Posted by 00pooterSS
Essentially yes they are, but the doors already have seals and moisture barriers and speakers generally last for many years with just the factory seals in the doors. So IMO they are unnecessary.
I made shields for mine since they get wet in the doors. The backs of mine had rusted the parts that weren't made for moisture. These doors are far from being water proof, which is why GM puts holes in the bottoms of the doors. If you want to keep those baffles, just cut the bottom off so the top is a shield and you should be good.
Old Mar 13, 2018 | 12:57 PM
  #32
00pooterSS's Avatar
Moisture also collects in the air so you will still have rust on the back of your speaker if it isn't sealed off from the moisture. A little rust on the back of them isn't something to be concerned with anyway.
Make sure your drain holes are clean, I've had several vehicles come in the shop with the holes plugged up and a gallon of water or so sitting in the doors. If they are clogged you may have more moisture than normal in your doors.
Old Apr 29, 2018 | 02:03 PM
  #33
1FastBrick's Avatar
Custm2500's Rude Friend
I am still looking and have not made up my mind. I was considering those Alpine SPS-610C How ever I have read a few reviews that the tweeters have failed after about a year. I was given a recomendation for the Kicker 43CSS674 both the main and the tweeters are made of a little better materials.
I have been told I can run the kickers with out an amp for now and should I decide to upgrade I can add an amp to get more power and maximise the speaker sound and capability.
Any thoughts on the Kicker recomendation over the Alpine's???
Old May 1, 2018 | 04:21 PM
  #34
00pooterSS's Avatar
Probably be fine with or without an amp on either. An amp will help any speaker set you choose, but obviously some speakers will handle more amp than others.
The kickers have a higher efficiency rating, so they will get louder on the same power level.
The kickers have a lower frequency range so if you'll be using these for bass you'll get a little bit more of the low end out of them, but they're still just door speakers so you'll only get so much.
I like that the kickers actually have a seperate crossover rather than just using a resistor as a bass blocker.
The kickers offer 3 tweeter loudness settings, which is nice.
Both sets are lower end component sets but will likely sound very good especially if you're replacing stock stuff with them. They both use metal/plastic tweeter material which (in my opinion) is too screechy. I prefer soft textile tweeter material, they play the highs just as well but are a little more balanced/soft in the delivery.
Check these out. Great frequency range, higher efficiency than either of the two you listed. Shouldn't need an amp.
https://www.crutchfield.com/p_108P65...cs.html?tp=106
Old May 1, 2018 | 04:27 PM
  #35
1FastBrick's Avatar
Thanks! I figure there probably better than what I will get in the 50-100 range from anywhere. Last time I went and got some from a local best buy. I was not happy and took them right back...
Funny thing, they dropped the price on the kickers and sent me an email this morning...
Old May 1, 2018 | 04:31 PM
  #36
00pooterSS's Avatar
Wait can't tell if you were referencing the speakers I posted or the speakers you posted.
Out of the options I would go with the ones I posted.
From what I've experienced even the best of speakers will not be near their full potential if you're going to use them on the stock radio/amp.
Old May 1, 2018 | 04:36 PM
  #37
1FastBrick's Avatar
Wait can't tell if you were referencing the speakers I posted or you.
Saw you edited after my response posted. I will look at those too.
You feel that would be a better choice?
It's basically a DD. I don't want to invest a ton of money into it in case it gets wrecked or stolen. I drive less than 10 miles round trip to work. And when I go to a job site It's not always in the best area and occasionally I have to park on the street.
Old May 1, 2018 | 04:42 PM
  #38
00pooterSS's Avatar
I would get these. These have basically the same exact specs as the infinity but these are silk tweeters and the tweeter level is adjustable
These have a 4.4 star rating from 600 people on amazon
https://www.crutchfield.com/S-hJbZyZ...L-GTO609C.html
Amazon Amazon
Old May 1, 2018 | 04:46 PM
  #39
00pooterSS's Avatar
Use those, no amp, get a JVC head unit. You can get great ones for around $200 or less and make a major difference. Run the speakers straight off the head unit. Put the foam rings on the speakers to the door panels. Be blow away by the difference.
Old May 1, 2018 | 04:50 PM
  #40
1FastBrick's Avatar
https://www.amazon.com/JBL-GTO609C-P...rimus+pr6500cs
Says there no longer availible on crutchfield.
