tach hookup 00 sierra 4.8
Old 06-19-2006, 10:18 AM
jeffwarlow's Avatar
Default tach hookup 00 sierra 4.8
I just got a proform monster tach and was wondering if anyone could tell me how to hook it up on my 2000 sierra 4.8l.
Thanks jeff
Old 06-19-2006, 11:24 AM
JOBLOW06's Avatar
Do You Have A Factory Tach In The Dash?
Old 06-19-2006, 11:27 AM
JOBLOW06's Avatar
Bulldog Securities Has A Great Wiring Diagram That I Followed On Their Site That Is Free To Access. It Lists The Color/location/function Of Each Wire You Will Need. Check It Out By Search Engine.
Old 06-19-2006, 12:16 PM
jeffwarlow's Avatar
Default re
I do have a factory tach. Thanks for the webitie I'm going to pull out the gauge cluster and take a look.
Thanks jeff
Old 06-20-2006, 03:58 PM
jeffwarlow's Avatar
Default re
No luck finding the wire on the cluster. So do I have to find the ecu and wire it from there.
Any help would be appreciated.
Thanks jeff
Old 06-23-2006, 12:06 PM
JOBLOW06's Avatar
You Didnt Find The White Wire Behind Your Guage Cluster? Thats Odd, I Have Installed A Couple Since Mine - And They Were All There. It Should Be Behind The Guage Cluster On The Driver Side Of The Pin Connection. I Think Its The Second Wire From The Drivers Side On The Top Row - But Im Not Sure. Be Sure To Take Out All 4 Bolts And Look Behind The Cluster. There Are Other Posts That Are Along This Line That Have Better Details. Check Out The Older Stuff. Dont Forget That You Have To Run This Tach Like A 4 Cylinder Motor( Which Requires Cutting I Think Both Brown And Tan Wires On Your Tach - Again - Double Check The Wires To Cut.) Otherwise You Will Only Read Half Of True Rpms On Your Tach. Something To Do With The Coil Packs Doing Something Blah Blah Blah - But Its True.
Dan Neumann
11
08-07-2022 09:06 AM
luis_bullz
09-08-2015 03:08 AM
CammedZ71
08-02-2015 01:44 AM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: tach hookup 00 sierra 4.8
