Sirius radio install in Silverado?
Old Dec 17, 2005 | 07:12 PM
ApacheDrill's Avatar
Default Sirius radio install in Silverado?
Where are you guys mounting the radios at? I see where there are a few places but with the antenna and power cord, your options are reduced.. Just curious what everyone else is doing and if you have pics..thats even better..Thanks Jim
Old Dec 17, 2005 | 07:45 PM
Let me add to this.. Its a external radio not the factory radio..
Old Dec 17, 2005 | 08:19 PM
goshawk23's Avatar
Truck addict
i have a sirius ready reciever so i don't have the add on box. however i mounted my ant on the roof. i have my wires running into the third break light. i placed the ant only as far away as the rubber molding strip would allow it to go away from the break light.
Old Dec 17, 2005 | 08:37 PM
Did you use the bracket for the windshield for the radio? If so how did u hide the wires?
Old Dec 21, 2005 | 02:06 PM
sikchevy's Avatar
i just installed the sirius one in my truck the other day. i ran the antenna from the roof through the third brake light, into the truck, down the drivers side, up into the fuse panel area, under the A pillar and to the unit which is mounted in the bottom left side of the windshield. i then took the power cable from the cig. lighter into the steering colum, then into the fuse panel, up the A pillar and into the unit. the only wires that are visable are the two coming from the unit. you see about a inch of them untill the go into the A pillar. hope that wasnt too confusing. go navy!
Old Dec 23, 2005 | 08:26 PM
goshawk23's Avatar
Truck addict
my wifes trailblazer as the external mount sirius sportster. i purchased a seperate mounting kit and it slid in between some of the dash pieces. the only wires you see is a small amount of the outlet wire. the rest were tucked into the dash
Old Dec 30, 2005 | 05:00 PM
smooth_addictions's Avatar
mine is in the glove box. it is a nice install took about a half hour. then the antena is on the dash on the passangers side by the piller.
LCHEE
Oct 24, 2020 04:10 PM
thunder550
Oct 8, 2015 04:53 PM
1bad2k
Aug 26, 2015 07:42 AM
atxlt
Jul 20, 2015 11:06 PM
