Running lights dont work
Old Feb 19, 2013 | 07:39 PM
NastyNate65's Avatar
Default Running lights dont work
Just bought a 95 Z71 with the 350 as a fixer upper. One of the problems is that the running lights dont work. Found the fuse blown, put another in and turned the lights on and right away blew the fuse. Headlights, cargo, brake, turn, and reverse lights all work just not the dash and running lights. Anyone deal with this before? I hate electrical problems, please help!!
Old Apr 28, 2013 | 11:59 AM
1customrides's Avatar
Registered User
if your fuse is blowing as soon as u turn them on then most likely u got a hot 12v wire that is touching the ground and needs to covered up. i would try and look at that wire and trace back to the switch starting from the bulbs
Old Jun 9, 2013 | 05:42 PM
AudioPh1x's Avatar
Yeah if you keep blowing the fuse you've got a short somewhere that needs to be found. Trace the wires from the DRLs and you might find it. Best of luck
Old Jul 25, 2013 | 12:46 PM
splash07s's Avatar
having a similar problem, I though it was a fuse so I replaced the $12 fuse under the hood and checked the smaller one and still gettin nothing.
04 2500HD silverado
ARC
57
Feb 21, 2022 10:54 AM
stealthperf
34
Feb 14, 2016 11:35 AM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
1320Chicken
Jul 14, 2015 10:58 PM
