Rear Power Locks What the.....
Old Apr 21, 2007 | 09:46 AM
BigCountryx's Avatar
Default Rear Power Locks What the.....
My rear doors do not lock using the remote or the power switches in the truck, but they do unlock if I have manually locked them. The Front doors operate fine. What in the world could be causing this?
Old Apr 26, 2007 | 11:01 AM
2k4tahoe's Avatar
there might be a relay somewhere that runs the back ones.
trace down wires and check for damage and/or relays.
Old Apr 26, 2007 | 12:00 PM
wonder if anyone has a diagram that might show this.
Old Apr 26, 2007 | 12:24 PM
Nick™'s Avatar
your truck is possessed. You need to sell it to me for $1 and let me deal with the problem
Old Apr 26, 2007 | 03:04 PM
budhayes3's Avatar
PT's Slowest Truck
Do you have an aftermarket alarm or remote start? If so, there may be a problem there. Also, I've had problems with my door lock actuators/latch assemblies in my truck (99 rcsb)...driver's side shorted leaving the dome light on as if the door were open (bad internal courtesy switch), and the passenger's side doesn't always lock on the first try, sometimes I have to hit the lock button a few times and it works (open circuit in the actuator assy).
Old May 3, 2007 | 03:23 PM
It's fixed, 2K4 you were right, it was just a matter of finding the right relay and replacing it. $28 buck later it's all good.
BTW- Nick, if I hadn't found the problem, I might have taken you up on your offer. But since it's fixed, I guess it's off the market.
Old Feb 21, 2008 | 04:07 PM
NoChrome's Avatar
you mind letting me in on what relay that was, cause mine lock but dont unlock, and its the rear doors only too...
Old Feb 24, 2008 | 10:14 PM
bigredexpress99's Avatar
there is a separate relay for locking and another one for unlocking the rear doors. Its in the fuse block on the LH side of the dash. Its probably the relay...I couldnt tell you how many I have put in.....
Old Feb 24, 2008 | 11:00 PM
BlownChevy's Avatar
blownerator
25 Year Member
been there, check the fuse
Old Feb 25, 2008 | 10:26 AM
NoChrome's Avatar
It was the relay, I swapped them and the issues changed thanks guys. All is well now.
ARC
57
Feb 21, 2022 10:54 AM
chopperloco
Jul 10, 2016 10:45 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Ketis
Jul 23, 2015 12:37 PM
