Question on wiring an amp
Old Nov 30, 2007 | 07:08 PM
04silverado912's Avatar
Default Question on wiring an amp
I just installed my system, and dummy me left my voltmeter at work. Im having problem getting the power to come on. There is no on or off switch, already looked, lol. Im wondering if its because the places i have the power and ground hooked up to. This is an 04 silverado btw. The power is at the small red box near the altenator. Then, i removed the plastic cover behind the seat to mount the speaker box down lower. I went to the jack, where the 2 studs come up for the ground. I scraped all the paint away, but I feel uneasy about it. where does everyone here get the power and ground from? Thanks in advance, Sean
Old Nov 30, 2007 | 07:33 PM
larsy87's Avatar
apple bottom jeans
Try rehooking your power to the positive on your battery terminal. Run your ground on the door jamb. Pull the plastic piece off the door sill and put it there. Wire stays hidden, I've stuck 1/0 under there!!
Old Nov 30, 2007 | 08:00 PM
where at in the door jamb are you hooking it to?
Old Nov 30, 2007 | 08:20 PM
larsy87's Avatar
apple bottom jeans
Theres a metal piece of the body, drill a hole and use a metal screw with washers. Grind the paint off as well. Then when your sure it works, spray it with some black paint so it doesn't rust.
Old Nov 30, 2007 | 08:27 PM
Also, i have side post terminals and seem to be having trouble hooking the lead to the terminal, any tips for that?
Old Nov 30, 2007 | 08:36 PM
larsy87's Avatar
apple bottom jeans
Are they setscrew or fork style?...not 100% sure what you mean
Old Dec 1, 2007 | 06:53 AM
viciousknid's Avatar
Where's the Beef?
is this an aftermarket amp? you should have a 3rd wire called a Remote wire that hooks to the radio. it's like an on switch. once it receives a power feed from that line it comes on.
USMCvet0311
Aug 1, 2015 07:45 AM
ou812sm
14
Jul 27, 2015 04:38 AM
ou812sm
Jul 23, 2015 02:11 PM
slowlsx
Jul 13, 2015 04:18 AM
