not too pleased with 08 bose system
Old Oct 14, 2008 | 06:11 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
yeah idk me personally i wouldn't go with that...even if it is a factory nav unit...look into kenwood...they have a nav unit that goes for like 1100 that's pretty friggin nice...it would save you a load of $$ in LOC's & not to mention i think with 3 LOC's youd end up runnin into interference problems...just my opinion though
Old Oct 14, 2008 | 06:13 PM
buster628's Avatar
ok please elaborate what do you think i should do
thanks
Old Oct 14, 2008 | 10:20 PM
OneQwikSS's Avatar
DDX712 - no nav but great unit...lookin at like 900$
LOC's are about 40 each
either way you'll need the RCA's but you'll get a better quality in sound with an aftermarket head unit...
but if you want to keep you're stock head unit it CAN be done...i just don't recommend it...you're best bet is to shop around a little while...see what's out there...weigh your options...draw up a list of pros vs. cons...
as far as what i said about interference...if you ground out the RCA's you won't get interference...but at the end of the day IMO you'll be better off and you'll have less headaches if you delete the factory amp & go with an aftermarket 5 channel run your doors to the 4 channels & the sub to the last...simple & sweet
Old Oct 14, 2008 | 11:06 PM
53bowtie's Avatar
LOC's are only $20 each and the point of this entire post is to build a good sounding(which in his particular case means louder than the stock bose) system while RETAINING his factory nav. I am sure if he knew he was going to replace the radio the second he bought it he would have not got the factory nav.
Also, he could take that $900 he would spend on a new nav to replace the one he already has and buy a jl clean sweep(or rockford 3sixty), the door speakers, the amp( agree with running a 5 channel, perhaps an alpine pdx?), and the subs. It is much more cost effective in his situation to keep the factory nav and the clean sweep or 3sixty should eliminate most if not all interference a cheaper LOC would be prone to.
Old Oct 15, 2008 | 12:30 PM
buster628's Avatar
thomas you know what your talking bout wish you were here in south texas to help me put this thing together...i looked into the jl clean sweep and they run about 200 seems pretty simple to set it up once i get that..... half of the work is done because that is going to be the key to be able to do what i want....im not looking for a ***** out bass machine just want more volume and some bumb if you guys know of anyone building boxes for these 08 silverado crewcabs please let me know and would you guys go with 8's 10' or 12's
thaks for all the info
Old Oct 15, 2008 | 07:16 PM
53bowtie's Avatar
you may have to have a local shop build you a custom box if you cant find a company like probox that makes them. There may not be any prefab boxes out for 08's yet. I would imagine 8's would be fine for what you are looking for.
Old Nov 7, 2008 | 07:14 PM
bud8fan's Avatar
Originally Posted by buster628
well thomas it sounds like im just going to have to change out those bose speakers for aftermarket which kicks the price up pretty good.... you would expect a name like bose to be able to hold more power than that....thanks for all you info
funny my sons and my '07's with bose and nav are as loud as we want them and his new '08 sux bad...it's 1/2 the sound of our '07's
Old Nov 7, 2008 | 10:41 PM
ss454327's Avatar
Has Bose changed the way they make their speakers? The older OEM Bose were .25ohm so you couldn't run a different amp than the factory one on them. There is a harness that allows you to use an aftermarket headunit with the speakers but I'm not sure about adding an aftermarket amp with the stock unit.
Old Nov 8, 2008 | 01:04 PM
53bowtie's Avatar
Most bose speakers in the newer gm vehicles are 8 ohm. But he is talking about replacing speakers as well so it would not matter for his application.
RJaxtheimer
Oct 31, 2015 07:58 PM
thunder550
Oct 8, 2015 04:53 PM
4B11T
Jul 13, 2015 03:48 PM
FlowmasterMufflers
Jul 9, 2015 12:00 PM
Nimoryan
Jul 5, 2015 03:50 PM
