Need some suggestions on a battery...
Well I decided to go with the optima yellow top. My local car audio shop only had yellow tops and I figured with the system, it couldn't hurt.
The truck started right up. Radio does actually sound a little crisper, but at full blast of my sub the lights still dim!!
I guess it's time to upgrade the alternator.
By the way how many amps/watts are you running in your system and what guage and length power wires are you running to them?
I'm running a kicker 750.1 and one 12" CVX. 4 ga wire. The length is not very long at all considering I have the amp behind the back seat on the same side as the battery.
I'll try out the big 3 mod soon and hopefully that will help.
That should help but a 750 watt amp even if its only powering one sub can still pull some amps. The 4ga wire should be just fine as long as you have a short ground cable. What kind of dim are we talking about after the battery upgrade? Similar to a power window being rolled up to the stops? More/Less drastic than a power window?
