Need some suggestions on a battery...
Old Aug 9, 2010 | 08:43 AM
Sc00by's Avatar
Originally Posted by collier341
Well I decided to go with the optima yellow top. My local car audio shop only had yellow tops and I figured with the system, it couldn't hurt.
The truck started right up. Radio does actually sound a little crisper, but at full blast of my sub the lights still dim!!
I guess it's time to upgrade the alternator.
I woudn't say you've been ripped. You have a great battery and if your lights are still dimming then any battery you would have bought would have done the same. The big 3 upgrade mentioned above holds some truth to the charging system. Any resistance taken out of the 12v equation can help big. Give that a try. If your still not satisfied have you thought of adding a second battery? I as well as several friends havent had any luck with capacitors and the money spent versus just adding a secondary battery. It just works....period.
By the way how many amps/watts are you running in your system and what guage and length power wires are you running to them?
Old Aug 9, 2010 | 02:59 PM
collier341's Avatar
I'm running a kicker 750.1 and one 12" CVX. 4 ga wire. The length is not very long at all considering I have the amp behind the back seat on the same side as the battery.
I'll try out the big 3 mod soon and hopefully that will help.
Old Aug 10, 2010 | 08:55 AM
Sc00by's Avatar
That should help but a 750 watt amp even if its only powering one sub can still pull some amps. The 4ga wire should be just fine as long as you have a short ground cable. What kind of dim are we talking about after the battery upgrade? Similar to a power window being rolled up to the stops? More/Less drastic than a power window?
Old Aug 17, 2010 | 12:57 PM
collier341's Avatar
the dim is fairly drastic... the volt meter jumps down atleast 1-2, maybe even 3 volts when the sub hits
Old Aug 17, 2010 | 01:21 PM
fastrt's Avatar
11 Second Truck Club
you need a capacitor!! your draining you charge. maybe 2 of them.
Gadgetized
Oct 22, 2015 09:06 AM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
The_W
Oct 1, 2015 02:35 PM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 04:22 PM
