lights flicker with amp.
Old Oct 10, 2007 | 08:13 AM
2k4tahoe's Avatar
Default lights flicker with amp.
how many folks are using a cap? or just dealing with the flickering?
Old Oct 10, 2007 | 10:24 AM
NoChrome's Avatar
that dimming is annoying and hard on your electrical system, caps are cheap and easy to install, I got one.
Old Oct 10, 2007 | 10:53 AM
truckmann's Avatar
Have you upgraded the wiring for your electrical system?
Caps can work, but don't use one as a bandaid for an improper charging system. A cap should be a last resort IMO. I have 2 amps, e-fans and notice very little light dimming without a cap.
Old Oct 10, 2007 | 11:09 AM
larsy87's Avatar
apple bottom jeans
Caps are a bandaid, as stated already. It's a lot cheaper to get 15 feet of 1/0 wire and redo the big 3, and you will most likely see the same, if not better results then a cap.
Old Oct 10, 2007 | 01:30 PM
NegraRCSB2X4auto's Avatar
i use a cap and it stopped the flickering. but I'm also selling an alternator that will work for you too. check the classifieds.
Old Oct 10, 2007 | 03:20 PM
Black-Jacket's Avatar
im going to be putting, a 400w kicker amp, kicker componets, kicker 4x6 and running my deck off the factory charging system(possible two 10's and a second amp later). think i should be ok with out a cap due to the fact i have the high output alternator and dual batteries
Old Oct 10, 2007 | 11:45 PM
53bowtie's Avatar
yeah, you will be fine.....
Old Oct 11, 2007 | 07:36 AM
2k4tahoe's Avatar
basically just upgrade all the wiring for the amp? i guess you could be right my T/A doesnt really flicker and i know its got like 4ga power and ground, but it has a smaller amp also.
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 28, 2015 08:24 AM
carid
Oct 1, 2015 09:22 AM
Lthompson
Sep 21, 2015 07:06 PM
