Help with dual alt wiring
High on diesel fumes
Hey guys, I posted this over on Tech and nobody has been able to give me a good answer other than recommending I change my setup. Reply over there if you want to reply, but take a look and see if you have any ideas....this is regarding my twin alt setup and only one running at any given time.
https://ls1tech.com/forums/showthread.php?t=459368
I have put my opinion over on LS1 Tech. I do understand that you don't want to install another battery. I do need some more information about the wire coming from the side connector, 1 of the wires feed the voltmeter, but what is the other for?
If that wire is a feed wire from the computer that might be your problem but not for sure. What are the volt reading on both alternators if one of the connectors is unplugged, I am thinking your problem might have something to do with the second wire on the side connector, but not for sure. I know on the 99 (at least my truck) they charge all the time even if the side connector is unplugged.
slowmo934
Sep 9, 2015 12:24 PM
wrb002
Aug 31, 2015 12:30 PM
