efans dont work??
Old Apr 29, 2006 | 10:35 PM
ap2002's Avatar
Default efans dont work??
efans dont work??
my efans dont work and neither does my a/c?? I went a bought new relays cause about a month ago that was the problem but now after the new relays they still dont work?? but if I open up one of the old relay while it was still on the harness and tap it together the fans will turn on..??? has anyone had this problem?? I dont know if the a/c is a seperate problem or not???
Old Apr 29, 2006 | 10:59 PM
FastCrewCab4x4's Avatar
Sounds like either the hot wire or the ground wire that control the relay doesnt have a good connection. cause if you can close the relay and it works, then it's a control wire problem. if you used a wire tap on your a/c then it may have severed the wire or the connection isn't good enough. check there first.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
creekrat
Aug 2, 2015 01:27 AM
ullose272
Jul 19, 2015 04:14 PM
01sierraon22s
Jul 8, 2015 11:26 AM
