Dash Bezel from 03+ into 00-02 for radio double din
Old 03-16-2007, 09:55 PM
  #31
11 Second Club
Phantom's Avatar
1slowhoe...where did you get your temp control with numbers? thats sweet
Old 03-18-2007, 08:56 PM
  #32
Destroyer of Transmissions
1SlowHoe's Avatar
Came that way stock. You can find them on ebay cheap from time to time.
Old 03-18-2007, 11:30 PM
  #33
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
So thats an 03+ bezel how the hell does it match up to the contour of the gauge cluster. They are shaped different. Or did I miss something?
Old 03-19-2007, 10:18 AM
  #34
1SlowHoe's Avatar
The gauge clusters are shaped the same. Different wiring harness and faceplates, but the overall shape is the same.
I had to grind the top of my ashtray down to get it to open and close and the flip up that hides the 3 12v sockets only opens about half way. Other than that it snaps right in like an 02 bezel.
Old 05-14-2007, 08:39 PM
  #35
PT's Slowest Truck
budhayes3's Avatar
Do you know if the 03 and up bezel comes in a light grey like my 99? If so, I think I've found my future nav/audio upgrade. Guess I could always paint the bezel also...
Old 05-15-2007, 01:43 PM
  #36
GTOsRamairSilverado's Avatar
Originally Posted by 1SlowHoe
I'm looking at an aftermarket, Kenwood. You wouldnt need the glove box. You need the dash bezel, the kick plate (part under the steering column) and the inside plastic part that the A/C controls mount to. The kick plate just makes it fit better. My 2002 one will work but its not a clean fit. Not enought to notice, but I notice. The plastic part for the A/C controls can be ground down and moved on my truck but the 03+ bolts in the same way and is already at the correct height. The 03's had very minimal dash changes that I can see other than the double din radio. I dont have any dea how to find the part number for the plastic part. Anybody work at a dealership? My local dealership cant find anything without a VIN. They are the definaition of lazy.
BTW, you cant open the ashtray with the new bezel either. I'm going to gring that down as well when I get it all together. The 3 12v sockets are still there as well but the door will only open about 75% before it hits the new bezel. Far enough to still use.
I need part numbers.
hey man, nice setup. is there any way that you could hook me up with a part number for the parts that you had to get to do your modification: bezel, plastic kick plate under steering colomn, and what else did you have to get ? any help would be appreciated.
Old 06-01-2007, 09:39 PM
  #37
TheBiz's Avatar
I used my 02 bezel in my avalanche. Just some creative and steady-handed dremel work and a custom radio kit....vualllla!
Linkage...
http://www.midwestavalancheclub.com/...sg9285#msg9285
Still needs some fiberglass and a quick paint, then she's done.
Old 06-01-2007, 10:00 PM
  #38
PT's Slowest Truck
budhayes3's Avatar
Linkage...
Looks good...another option to consider if I ever go the double din route...
drummer0415
11
10-24-2015 08:16 PM
someotherguy
10-05-2015 12:49 PM
CD82
09-28-2015 11:32 PM
pewter00
09-14-2015 09:17 PM
sprayed99
09-14-2015 12:36 PM
Quick Reply: Dash Bezel from 03+ into 00-02 for radio double din
