Dash Bezel from 03+ into 00-02 for radio double din
#34
Destroyer of Transmissions
The gauge clusters are shaped the same. Different wiring harness and faceplates, but the overall shape is the same.
I had to grind the top of my ashtray down to get it to open and close and the flip up that hides the 3 12v sockets only opens about half way. Other than that it snaps right in like an 02 bezel.
#36
Originally Posted by 1SlowHoe
I'm looking at an aftermarket, Kenwood. You wouldnt need the glove box. You need the dash bezel, the kick plate (part under the steering column) and the inside plastic part that the A/C controls mount to. The kick plate just makes it fit better. My 2002 one will work but its not a clean fit. Not enought to notice, but I notice. The plastic part for the A/C controls can be ground down and moved on my truck but the 03+ bolts in the same way and is already at the correct height. The 03's had very minimal dash changes that I can see other than the double din radio. I dont have any dea how to find the part number for the plastic part. Anybody work at a dealership? My local dealership cant find anything without a VIN. They are the definaition of lazy.
BTW, you cant open the ashtray with the new bezel either. I'm going to gring that down as well when I get it all together. The 3 12v sockets are still there as well but the door will only open about 75% before it hits the new bezel. Far enough to still use.
I need part numbers.
#37
I used my 02 bezel in my avalanche. Just some creative and steady-handed dremel work and a custom radio kit....vualllla!
Linkage...
http://www.midwestavalancheclub.com/...sg9285#msg9285
Still needs some fiberglass and a quick paint, then she's done.
Linkage...
#38
Linkage...
Linkage...
drummer0415
11
Oct 24, 2015 08:16 PM
someotherguy
Oct 5, 2015 12:49 PM
