Bose premium to luxury amp upgrade 03 crew cab
Old Jun 18, 2016 | 11:22 AM
3500Silverado's Avatar
Default Bose premium to luxury amp upgrade 03 crew cab
I've got an 03 crew cab 3500 LT. I replaced the factory 6 disc head unit with a killer Pioneer head unit, the sound got a lot better. I'm now going to replace the door speakers and the A pillar tweeters with Pioneer stuff. I was thinking about an 8" Pioneer subwoofer, too. Doing a search on the subject, I found a little information about a significant improvement being possible by upgrading my original premium system Bose amp to a luxury system Bose amp, from a GMC or Cadillac. Can anyone tell me the part number of the best amp(s) for this? Also, the wiring diagrams to do the swap?
Thanks!
Old Jun 18, 2016 | 02:05 PM
1FastBrick's Avatar
Custm2500's Rude Friend
check here https://www.performancetrucks.net/fo...mt800s-496180/
Old Jun 20, 2016 | 05:01 PM
Suburbazine's Avatar
I would recommend ditching the Bose amp totally. You CANNOT use the Luxury Bose amp with an aftermarket head unit, only the OE Lux head unit or an OE Mid headunit that has been modified (and I haven't heard anything from the guy that was doing the modding for a few years now). The Lux amp requires the head unit to send not only Low-level fixed audio, but a Class 2 databus signal to modulate the audio and EQ options.
A dedicated 4 channel amp and a subwoofer amp will go a much longer ways than any Bose option.
Old Jun 20, 2016 | 05:29 PM
Interesting. Because according to the tech at Crutchfield, and one of the guys who wrote the tech pages on swapping to the "luxury" Bose amp, both said that my Pioneer head unit, and the PAC GM11 interface I bought with it, both work with the Bose "luxury" amp. All that is necessary is the wiring swap.
Old Jun 20, 2016 | 06:25 PM
They were incorrect. That would work fine for the midlevel Premium Bose amplifier which didn't really care about input levels and didn't have a built in DSP. You are welcome to try, but the Lux amp won't work with variable outputs from an aftermarket head unit and won't even power up without the proper Class 2 signal (which the GM11 may or may not provide). The documentation claims to support Premium (not luxury) amps:
  • Retains factory BOSE audio systems
  • Retains factory premium BOSE audio (does not support fading)
It wouldn't hurt to test, though (ok, I take that back, you'll probably kill your new Lux amp). Maybe PAC pulled off support for the luxury amps somehow. The fixed level audio voltage is a piddly 500mv, any more makes the Lux amp go poof.
FYI, the Bose Lux amp can only push 55w down the sub channel @ 4ohms minimum load. Not good enough for most aftermarket subs.
Here's the wiring changes needed:
https://docs.google.com/file/d/1UAMV...nsMFl5bgt/edit
https://docs.google.com/document/d/1...J-oNX6Y8U/edit
Old Jun 21, 2016 | 06:11 AM
About20ninj45's Avatar
Although mine isn't a "swap" I did remove my cdx and add an aftermarket radio while keeping my lux amp. Sounds great and the stock amp handles it just fine. I'm also running an aftermarket amp for just the subs though.
Old Jun 21, 2016 | 08:58 AM
Maybe the tech guy at PAC is wrong, but I received an email from them this morning saying that the PAC interface and Pioneer head unit I have in my truck are a direct fit for an 06 Escalade, which is what the amp I'm buying came from. I actually found a complete luxury amp, console wiring harness, and luxury subwoofer, with the sound mic, I may go that route, for $35 more than just the amp.
Old Dec 3, 2016 | 10:25 PM
Well, it is together, and it works fine. My biggest complaint is that the Bose amp sends frequencies to low for the speakers out to the door speakers. But it all works fine, and sounds much better than the OE stuff.
I did however install a 400 watt amp, bridged, for the 8" subwoofer. Getting the amp and the subwoofer in the console is a real pain. But I still have all of the storage space behind and under the rear seat.
Old Dec 5, 2016 | 04:34 AM
Congrats!!!! Post up some pictures!!
Old Dec 7, 2016 | 12:01 AM
SilverSquared's Avatar
I had the LUX factory setup in my truck (02 ecsb esky conversion). The console sub still plays. I upgraded to a JVC DD Head unit and utilized factory steering wheel controls. Front speakers in doors are a pieced together component system, rear doors are 6.5 coaxials and I have a pair of subs under the rear seat.
Sad to see how many were hyped about the Bose systems. The sub produces bass, better than nothing, but the door speakers are an absolute joke.
Front door 6.5" Comparison, Bose to American Bass. (Polk dB X-Overs and Massive Audio DT-05 Tweets used for components)
And my pair of 6.5" American Bass subs. (Transmission, or T-Line, style enclosure, due to labyrinth venting, subs mounted on outside for room)
