Aux IPOD port.
Old Mar 9, 2009 | 08:12 PM
gxrior's Avatar
Question Aux IPOD port.
I have a 2001 Silverado.
All stock stereo.
The tape player is separate and below the 1.5 din CD receiver.
There is a harness from the receiver to the tape deck.
There has to be a way to splice in a 3.5mm jack to plug in my ipod without buying a kit for 100 bucks!
ANY HELP?
Old Mar 9, 2009 | 10:22 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
use a FM modulator...you can find them for 50 - 60 bucks at wal mart...best buy...places like that...or check metraonline.com they might have a wire for your truck
Old Mar 10, 2009 | 11:07 AM
icedenali's Avatar
best way is to use fm modulator they dont cost a lot about 40-50 bucks.
and u will also need antena extension.
Old Mar 10, 2009 | 11:39 AM
BIRCHZ71's Avatar
not sure if you have an earphone jack but if you do they sell the aux wire that connects ur ipod to the earphone jack and it sounds perfect. that's what i did as i had horrible luck with the fm transmitters.
Old Mar 10, 2009 | 02:58 PM
red87iroc's Avatar
Need the wiring diagram. Need to know plus and minus for left and right channel, but I think you also need a way to send a signal back to the head unit that the ipod is playing, so it is using the signal from the aux input and not from any other source.
I have found an Axxess AIP-GM02-ID on Amazon.com for around $30 used, and it is an iPod adapter made to work with the Cassette head units with the CD units in the console. I've been tempted to buy it and see if it would work with the CD head unit.
Old Mar 13, 2009 | 11:12 AM
blueflamed03's Avatar
www.soundgate.com
look for GMPD2, lets you use stock steering wheel controls,etc if you have those.
Old Mar 13, 2009 | 03:05 PM
Toadster's Avatar
$2.99 http://www.overstock.com/Electronics...6/product.html
just pop the tape in and connect your iPOD (or anything with a mini-din connector)
Old Mar 15, 2009 | 10:11 PM
larsy87's Avatar
apple bottom jeans
If your going to spend 50-60 bucks on an FM transmitter you might as well pony up 100 bucks for something hard wired, FM transmitters are garbage.
5.3Okasai
Mar 9, 2022 01:07 PM
drummer0415
11
Oct 24, 2015 08:16 PM
Closer_2001
Sep 24, 2015 09:15 PM
Verz
Aug 21, 2015 06:40 PM
