2 single din units into a double din
Old Jan 28, 2009 | 09:47 AM
ou812sm's Avatar
Default 2 single din units into a double din
does anyone know if its possible to put 2 single din units into a double din spot and how hard is it to do
Old Jan 28, 2009 | 10:18 AM
00ChevyScott's Avatar
Wearin' da big hat
Why?
I'm sure it's possible with some custom work, but I'd be afraid they would overheat up against eachother like that.
Old Jan 28, 2009 | 10:38 AM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by 00ChevyScott
Why?
I'm kinda with him on this one. why not just buy a double din?? All of the wiring would have to be ran into one harness on this.. Curious?? To be different??
Old Jan 28, 2009 | 11:41 AM
ou812sm's Avatar
no i want the sound quality of a pioneer DEH-P800PRS and have a flip out screen when i want to use it the one i was thinking is AVH-P5100DVD if i could put them together could this work
Old Jan 28, 2009 | 07:55 PM
ou812sm's Avatar
bump anyone think that this will work
Old Jan 28, 2009 | 10:11 PM
flossinon_24s's Avatar
its very easy to do and metra even makes a dash kit to do it. it is part number 99-2003.
Old Jan 29, 2009 | 08:16 AM
ou812sm's Avatar
it easy to do but should i be concerned about heat
Old Jan 29, 2009 | 11:07 AM
BLK WDO's Avatar
heat.... maybe, but with one running and the other not then no. if both are running at the same time then maaaybe. cut a slit into the center air vent and just direct a little air to them to move the hot air away from it and should b fine
Old Jan 29, 2009 | 01:19 PM
53bowtie's Avatar
You shouldnt have any problems with heat. This type of setup is run by many people in the SQ compititions that are daily drivers with no problems.
Thomas
Old Jan 30, 2009 | 11:27 AM
ou812sm's Avatar
does any know how to run the sound from one unit into the other
