08 Tahoe - speakers
Old Nov 4, 2007 | 09:22 AM
MislMan's Avatar
Default 08 Tahoe - speakers
I am looking to change the speakers in the front doors on my 2008 Tahoe. Does anyone know where all of the attaching hardware is located to remove the inner door panel. So far I have only found one bolt behind the inside door lever and one bolt under the small cover behind the inside pull handle. Anyone know for sure where others are located? Might be the same for a 2007 Tahoe or Escalade.
Thanks for your help ... Larry S.
Old Nov 5, 2007 | 12:52 AM
UnrthdxDream's Avatar
look on the bottom of the door panel? there is a bolt on the 99-07 trucks that you can only see if you layin down on the ground. wish i could be of more help but i'm not familiar with the new trucks!
Old Nov 9, 2007 | 05:52 PM
MislMan's Avatar
Thanks for the reply. No visible bolts on the bottom surface laying down and looking straight up to the sun.
... Larry S.
Old Nov 10, 2007 | 07:29 AM
53bowtie's Avatar
do you have to do anything with the window/door lock controls on it? sometimes there is a screw behind there......
Old Nov 10, 2007 | 08:11 PM
Larry I know when I replaced my speakers from my 06 Silverado I had the screw behind the door lever, 2 screws where the power windows/locks are located (I had to remove that panel) then I had clips behind the door panels all the way around about every 4 inches.
I have not looked at my 07 Suburban but I know nothing has chenged for 08 in this area.
Good luck
Sean
Old Nov 11, 2007 | 08:00 AM
MislMan's Avatar
Thanks all ... I believe I have tried the most common areas. A small panel or 2 look like they could be pried off and have a screw or bolt hidden under them. However, the small panels do not raise easily so I have been hesitant to pry too hard fearing I would snap something off. The inner panel feels like it needs to lift up off of some sort of bayonet fitting on the inner door structure.
Well, no hurries to get this done so I'll keep searching. Maybe a dealership or local auto body shop will be willing to enlighten me to the location of all the bolts.
Thanks again .. Larry S.
Old Nov 11, 2007 | 09:27 AM
53bowtie's Avatar
yes, pull up and out to remove the door panel, dont pull straight out!
Old Nov 11, 2007 | 03:36 PM
If you stop by the dealership they will have diagrams that you can look at in the parts department. They also sell new clips in case you break them like I did
Old Nov 13, 2007 | 03:34 AM
Blown02Sierra's Avatar
Actually, those dont need to come out to remove the door panels. They just hold the pockets in.
Texas5.3_1251
Mar 5, 2016 08:10 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
97_ek
Sep 23, 2015 09:16 PM
the owl
Sep 4, 2015 04:09 PM
