07 chevy silverado nnbs kill switch
Old Sep 7, 2016 | 06:31 PM
erniedogg1's Avatar
Question 07 chevy silverado nnbs kill switch
Has anyone ever installed a kill switch on their truck? What would be the best way of doing it? ThruFuel pump wiring ,ignition ? Wanting to install one on my truck any help would be appreciated thanks
Old Sep 7, 2016 | 10:41 PM
Staggered 02's Avatar
A friend of mine had it installed interrupting the fuel pump. Another tied in to the ignition system. A very wise idea.
Old Sep 8, 2016 | 08:49 AM
Chris Brinkley's Avatar
Registered User
The best technique I have seen is to unplug the ground from the ECU. If you disconnect ground it is very uncommon and will make it so that even if you have fuel the truck won't run.
When you do a fuel pump cut off it is common and people know where to look, same with the ignition.
Old Sep 8, 2016 | 10:06 AM
Atomic's Avatar
I have a gauge for that
You can get real fancy and put in multiple breaks. Like for instance you have to hold a button while pressing the brake pedal to start it. If either isn't pressed while cranking it wont start.
Old Sep 11, 2016 | 05:25 PM
erniedogg1's Avatar
Thanks for the ideas that ecu one does sound like the most uncommon
Sexyrado327
Apr 25, 2017 03:35 PM
LIL SS
Sep 20, 2016 07:36 AM
RA62025
Sep 13, 2016 04:11 PM
Lbzduramax
Sep 8, 2016 10:16 PM
supershift67
Sep 7, 2016 12:01 AM
