segment swap wiring
Old Sep 2, 2016 | 04:08 PM
Lbzduramax's Avatar
Default segment swap wiring
quick question on the segment swaps. Do you need to do all the same wiring ( changing the pins at the PCM mostly)
Everything in the photo below??
Old Sep 2, 2016 | 05:13 PM
Jake75's Avatar
You put the brown wire in the u slot on the trans plug no need to change the pcm side of the brown wire. The white and tan/white wire will be re purposed for the new speed sensor and those will be pinned on 22 and 23 in the red pcm connector
Old Sep 6, 2016 | 03:12 PM
Lbzduramax's Avatar
Ok that's what I had thought. After figuring out that I had the new speed sensor in the wrong spot I rewired it the correct way and now the Trans is stuck in 2nd gear while going forward 😡
Old Sep 6, 2016 | 05:08 PM
parks450's Avatar
Check for pinched works or your 1-2 shift solenoid.
Old Sep 7, 2016 | 05:45 PM
Lbzduramax's Avatar
Commanding the solenoids on and off I can hear them working in the trans
Old Sep 8, 2016 | 06:59 PM
LongBlue's Avatar
Assuming this is not on an NNBS?
Old Sep 8, 2016 | 09:26 PM
Lbzduramax's Avatar
No trucks a 2001
Old Sep 8, 2016 | 10:13 PM
tgui's Avatar
I did a 2002 Yukon 80e swap like you're doing. Find my thread.
That said I had a bad valve body that kept me in 2nd gear.
Have you done pressure tests?
Old Sep 8, 2016 | 10:16 PM
tgui's Avatar
Also be sure to pull codes often. Some will put your trans in limp mode in short order. Once again, my dumbass knows first hand.
Tech@B&M Racing
Nov 7, 2016 08:59 PM
dswitzer9865
Sep 19, 2016 03:07 PM
Wolftrk99
Aug 30, 2016 08:14 PM
JOSH_THE_PEDDLER
Aug 28, 2016 11:38 PM
rocknZ71
Aug 28, 2016 11:42 AM
